Home > Maintenance & Modifications > Centre dash light bleeding though |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20292 |
Click image to enlarge Click image to enlarge ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
29th Sep 2019 8:32pm |
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4795 |
It’s the same on mine Steve, drives me nuts perhaps with a hot glue gun it could be glued down to close the gap? 2015 HT XS 90
2008 SVX 90 2000 XS TD5 90 |
29th Sep 2019 8:38pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Looks good
I have light bleeding from the hot & cold knob My new HD unit dims when I use the lights which is good |
29th Sep 2019 8:41pm |
I did suspect I may not be the only one hence mentioning it.
I’m happy with the result, just that annoying little issue. I have some of these LED chips left over if anyone wants a set? I haven’t counted how many I have left but I think there are at least a set or two left. If anyone wants some let me know FOC. I have a few more pics somewhere. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
29th Sep 2019 9:33pm |
This was the clock repair. Not an LED, I don’t have any more of these but RDX do them. About £6 vs LR wanting you to buy a new clock! @ £60 approx when it was just a blown bulb.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
29th Sep 2019 9:38pm |
This is the LED chips. I have one set 4x spare.
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Out with the old, in with the new: ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
29th Sep 2019 9:42pm |
Steve are these a straight swap or do they require soldering etc? If they are a straight swap may I have them please? 2015 HT XS 90
29th Sep 2019 9:56pm |
Simon - Yep, course you can. Straight swap. Just be sure to check polarity is correct orientation and they are working before putting the dash back in.Pop me your address by ‘PM’ and I can stick them in the post for you. 👍🏻 ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
29th Sep 2019 10:00pm |
LR110 BG Member Since: 02 Apr 2019 Location: Wiltshire Posts: 16 |
Hi Steve,
I don’t suppose you ha s part number or where you ordered them from? As I need a new clock bulb. |
30th Sep 2019 8:39pm |
For the dash bulb RDX via eBay.
It is an incandescent bulb with green cover, I don't think there is any LED solution. LR don't sell any spare bulbs or parts only the clock its self for over £60 a piece. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️ |
30th Sep 2019 10:15pm |
Bulbs arrived today many thanks Steve.
Will let you know if the blacktac fix works 2015 HT XS 90 2008 SVX 90 2000 XS TD5 90 |
1st Oct 2019 5:32pm |
Fitted today and wow much brighter thanks Steve. I put a little sausage shaped piece of blacktac along the area you were having the light bleed from as I was too and this has worked to prevent the bleed and the functions all work correctly too on the heater sliders 2015 HT XS 90
12th Oct 2019 8:00pm |
12th Oct 2019 8:10pm |
