Home > Maintenance & Modifications > Centre dash light bleeding though
I did some work on my 90 today. Changed the clock bulb which was gone before so it now illuminates as it should which was a success.
I also had a few bulbs gone again on the heater slider controls again. Rolling Eyes
I decided this time to give LED's a go the new SMD 3 directional SMD chip type, in the lower control assembly.
I'm quite happy with the outcome they are crisp white, the green dash filters obviously turn this green as it should.
There is the odd lighter and darker bits but that's pretty typical as standard with ordinary bulbs!
There is one annoying issue I have, and it doesn't seem to matter what centre dash I use. (I have two.)
Or what bulbs or type I use but some white light bleeding comes though in the lower edge aperture just below the 1 2 3 fan speed slider.
It's quite annoying as I've tried two different dashes, both have done it in the same location.
Yes, it is worse since this bulb change but other than this niggle I'm happy with it.
They'll run cooler, abd last longer.
It seems to be the part between the centre dash and the black plastic slider there seems to be a little gap there.
I imagine me removing then re-fitting the dash has slightly disturbed it.
The black plastic slider seems to be not quite so snug to the dash as it should be but obviously cannot be too tight.
I notice look at the pics I've taken there are a few screws M2.5 maybe?
On the slider assembly.
I wonder if a washer could go behind those between the white plastic assembly and black slider and that would close that gap up?
It's just a little annoying as in that vicinity all the lighting is good and green, no problem but you get a little white border in places around those slider controls and obviously it looks wrong and is annoying.
It's the upper one mainly that's the culprit.
It could be that the slider is a little out of true due to work done in the past, I had a control cable kink on the lower slider I had to replace but the upper slider may have got moved around a bit.
What do you think?
Here is a photo or two of the culprit: WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #795909 29th Sep 2019 9:31pm
Post #795911 29th Sep 2019 9:32pm
Sulisuli
It’s the same on mine Steve, drives me nuts Big Cry perhaps with a hot glue gun it could be glued down to close the gap? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #795914 29th Sep 2019 9:38pm
mick
Looks good
I have light bleeding from the hot & cold knob Rolling Eyes
My new HD unit dims when I use the lights which is good
Post #795916 29th Sep 2019 9:41pm
I did suspect I may not be the only one hence mentioning it.
I’m happy with the result, just that annoying little issue. I have some of these LED chips left over if anyone wants a set?
I haven’t counted how many I have left but I think there are at least a set or two left. If anyone wants some let me know FOC.
I have a few more pics somewhere. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #795938 29th Sep 2019 10:33pm
This was the clock repair. Not an LED, I don’t have any more of these but RDX do them. About Β£6 vs LR wanting you to buy a new clock! @ Β£60 approx when it was just a blown bulb.
Post #795939 29th Sep 2019 10:38pm
This is the LED chips. I have one set 4x spare.
Out with the old, in with the new: WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #795942 29th Sep 2019 10:42pm
Sulisuli
Steve are these a straight swap or do they require soldering etc? If they are a straight swap may I have them please? 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #795943 29th Sep 2019 10:56pm
Simon - Yep, course you can. Straight swap. Just be sure to check polarity is correct orientation and they are working before putting the dash back in.Pop me your address by β€˜PM’ and I can stick them in the post for you. πŸ‘πŸ» WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #795945 29th Sep 2019 11:00pm
LR110 BG
England 2009 Defender 110 Puma 2.4 SW Santorini Black
Hi Steve,
I don’t suppose you ha s part number or where you ordered them from? As I need a new clock bulb.
Post #796112 30th Sep 2019 9:39pm
For the dash bulb RDX via eBay.
It is an incandescent bulb with green cover, I don't think there is any LED solution.
LR don't sell any spare bulbs or parts only the clock its self for over Β£60 a piece. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #796132 30th Sep 2019 11:15pm
Sulisuli
Bulbs arrived today Bow down many thanks Steve.
Will let you know if the blacktac fix works Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #796223 1st Oct 2019 6:32pm
Sulisuli
Fitted today and wow much brighter thanks Steve. I put a little sausage shaped piece of blacktac along the area you were having the light bleed from as I was too and this has worked to prevent the bleed and the functions all work correctly too on the heater sliders Thumbs Up 2015 HT XS 90
2008 SVX 90
2000 XS TD5 90
Post #797884 12th Oct 2019 9:00pm
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #797886 12th Oct 2019 9:10pm
