![]() | Home > eBay & Bargain Spots > Links to correct engine oils on AMAZON |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6647 ![]() ![]() ![]() |
Hi all,
Here is a list of links to the correct engine oils for the Defender 2.4 Puma being sold on Amazon. All are available with FREE next day delivery with Prime, a free 30 day trial is available using the banner below: ![]() Click here for your free Prime trial Prices on Amazon fluctuate so please check the links for latest prices. The oil change capacity for the 2.4 Puma is 7.0 litres and an oil change guide is here: https://www.defender2.net/forum/topic8707.html All these oils meet the required Ford specification of WSS-M2C 913-C or 913-D. Comma XTech 5W-30 - 5 litres ![]() Click here to buy on Amazon.co.uk Mobil Super 3000 X1 Formula FE 5W-30 - 5 litres ![]() Click here to buy on Amazon.co.uk Total Quartz 9000 Future NFC 5W-30 - 5 litres ![]() Click here to buy on Amazon.co.uk Motul 8100 Eco-nergy 5W-30 - 5 litres ![]() Click here to buy on Amazon.co.uk TITAN Supersyn F Eco-DT SAE 5W-30 - 5 litres ![]() Click here to buy on Amazon.co.uk Castrol Magnatec Stop-Start A5 5W-30 - 4 litres Note that Castrol oils are supplied in 4 LITRE can. ![]() Click here to buy on Amazon.co.uk This list will be expanded soon to the Td5 engines ![]() Any other oils and deals you find please share and I'll update this post ![]() ![]() ![]() Last edited by Martin on 7th Oct 2019 11:56am. Edited 1 time in total |
Hi all,
Here is a list of links to Amazon of the correct engine oils for the Defender 2.2 Puma with DPF. All are available with FREE next day delivery with Prime, a free 30 day trial is available using the banner below: ![]() Click here for your free Prime trial Prices on Amazon fluctuate so please check the links for latest prices. The oil change capacity for the 2.2 DPF Puma is 6.9 litres and an oil change guide is here: https://www.defender2.net/forum/topic8707.html All these oils meet the required Ford specification of WSS-M2C 934-B. Shell Helix Diesel Ultra AF-L SAE 5W30 - 5 litres ![]() Click here to buy on Amazon.co.uk Comma Ecolife 5W-30 - 5 litres ![]() Click here to buy on Amazon.co.uk EXOL Optima C1 LSZ 5W-30 - 5 litres ![]() Click here to buy on Amazon.co.uk Motul 8100 Eco-Clean+ 5W-30 - 5 litres ![]() Click here to buy on Amazon.co.uk Millers XF Longlife C1 5W-30 - 5 litres ![]() Click here to buy on Amazon.co.uk Any other oils and deals you find please share and I'll update this post ![]() ![]() ![]() Last edited by Martin on 7th Oct 2019 11:56am. Edited 2 times in total |
(saved for Td5)
Will be yes 👍🏻
Rashers Member Since: 21 Jun 2015 Location: Norfolk Posts: 3587 ![]() ![]() ![]() |
Handy link and information. Thanks Martin
Martin, good reminder of correct oils for the different engines.
One question. Is it correct that all these oils suitable for the 2.2 Puma with DPF are also ok to use in the 2.4 Puma, but not the other way around? Best, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 ![]() ![]() ![]() |
Great idea 1951 80" S1 2.0
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2663 ![]() ![]() ![]() |
Yep, that's the case, because the DPF needs special stuffs in the oil ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
I wouldn't recommend using an oil of a different spec than that stipulated by the manufacturer.
The 2.4 is 913C or 913D, 2.2 with DPF is 934B ![]() ![]() |
Stu_XS Member Since: 22 Jul 2018 Location: Hampshire Posts: 86 ![]() ![]() ![]() |
2.2 with DPF engine oil - https://catalog.lubricants.total.com/en/pr...O-C1-5W-30
2.2/2.4 Diff/Transfer Box/Gearbox - http://catalog.lubricants.total.com/en/pro...-FE-75W-90 2.2/2,4 Coolant - https://catalog.lubricants.total.com/en/pr...-SUPRA--37°C General purpose grease - https://catalog.lubricants.total.com/en/pr...ULTIS-EP-2 Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1107 ![]() ![]() ![]() |
Thanks Stu for posting non-amazon links
You’re welcome. The links I shared are information only, no sales option.
I suspect the amazon links are affiliated links so the forum could take a small bit of revenue towards running costs. Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
Your choice to use Amazon or not, there’s no pressure just some helpful links if you want them.
The revenue from the affiliate links is tiny, not going to be retiring on the back of it. ![]() ![]() |
I wasn’t having a dig, just trying to give some explanation.
To be honest I expected you have converted the links I posted to Amazon. Stu... 2013 Aintree Green 90 XS SW 2.2 Puma |
