Home > eBay & Bargain Spots > Links to correct engine oils on AMAZON
Martin
Site Admin
Hi all,
Here is a list of links to the correct engine oils for the Defender 2.4 Puma being sold on Amazon.
All are available with FREE next day delivery with Prime, a free 30 day trial is available using the banner below:
Click here for your free Prime trial
Prices on Amazon fluctuate so please check the links for latest prices.
The oil change capacity for the 2.4 Puma is 7.0 litres and an oil change guide is here: https://www.defender2.net/forum/topic8707.html
All these oils meet the required Ford specification of WSS-M2C 913-C or 913-D.
Comma XTech 5W-30 - 5 litres
Click here to buy on Amazon.co.uk
Mobil Super 3000 X1 Formula FE 5W-30 - 5 litres
Total Quartz 9000 Future NFC 5W-30 - 5 litres
Motul 8100 Eco-nergy 5W-30 - 5 litres
TITAN Supersyn F Eco-DT SAE 5W-30 - 5 litres
Castrol Magnatec Stop-Start A5 5W-30 - 4 litres
Note that Castrol oils are supplied in 4 LITRE can.
This list will be expanded soon to the Td5 engines Thumbs Up
Any other oils and deals you find please share and I'll update this post Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #797085 7th Oct 2019 11:16am
Martin
Site Admin
Hi all,
Here is a list of links to Amazon of the correct engine oils for the Defender 2.2 Puma with DPF.
The oil change capacity for the 2.2 DPF Puma is 6.9 litres and an oil change guide is here: https://www.defender2.net/forum/topic8707.html
All these oils meet the required Ford specification of WSS-M2C 934-B.
Shell Helix Diesel Ultra AF-L SAE 5W30 - 5 litres
Comma Ecolife 5W-30 - 5 litres
EXOL Optima C1 LSZ 5W-30 - 5 litres
Motul 8100 Eco-Clean+ 5W-30 - 5 litres
Millers XF Longlife C1 5W-30 - 5 litres
2015 D90 XS SW
Post #797088 7th Oct 2019 11:42am
Martin
Site Admin
(saved for Td5)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #797089 7th Oct 2019 11:42am
excossack
Thanks Martin. Is this link also going to include Diff/transfer case and gearbox oils? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #797364 9th Oct 2019 7:49am
Martin
Site Admin
Will be yes 👍🏻  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #797470 9th Oct 2019 7:38pm
Rashers
Handy link and information. Thanks Martin Thumbs Up
Post #797472 9th Oct 2019 7:40pm
ericvv
Martin, good reminder of correct oils for the different engines.
One question. Is it correct that all these oils suitable for the 2.2 Puma with DPF are also ok to use in the 2.4 Puma, but not the other way around?
Best, Eric You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #797512 10th Oct 2019 2:22am
familymad
Great idea 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #797826 12th Oct 2019 9:36am
Naks
Best, Eric
Yep, that's the case, because the DPF needs special stuffs in the oil Thumbs Up --
Post #798592 18th Oct 2019 5:54am
Martin
Site Admin
I wouldn't recommend using an oil of a different spec than that stipulated by the manufacturer.
The 2.4 is 913C or 913D, 2.2 with DPF is 934B  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #798625 18th Oct 2019 11:09am
Stu_XS
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Aintree Green
2.2 with DPF engine oil - https://catalog.lubricants.total.com/en/pr...O-C1-5W-30
2.2/2.4 Diff/Transfer Box/Gearbox - http://catalog.lubricants.total.com/en/pro...-FE-75W-90
2.2/2,4 Coolant - https://catalog.lubricants.total.com/en/pr...-SUPRA--37°C
General purpose grease - https://catalog.lubricants.total.com/en/pr...ULTIS-EP-2 Stu...
2013 Aintree Green 90 XS SW 2.2 Puma
Post #798810 19th Oct 2019 9:04pm
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
Thanks Stu for posting non-amazon links Thumbs Up Do we really need to buy even oil from amazon??
Post #800530 2nd Nov 2019 9:41pm
Stu_XS
You’re welcome. The links I shared are information only, no sales option.
I suspect the amazon links are affiliated links so the forum could take a small bit of revenue towards running costs. Stu...
Post #800537 2nd Nov 2019 10:09pm
Martin
Site Admin
Your choice to use Amazon or not, there’s no pressure just some helpful links if you want them.
The revenue from the affiliate links is tiny, not going to be retiring on the back of it.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #800539 2nd Nov 2019 10:14pm
Stu_XS
I wasn’t having a dig, just trying to give some explanation.
To be honest I expected you have converted the links I posted to Amazon. Stu...
Post #800541 2nd Nov 2019 10:17pm
