Home > Maintenance & Modifications > Vented the way?
bear100
Vented the way?
With a sticky ns front caliper an overhaul is imminent, looks like I’ve had non genuine calipers fitted at some stage.
So while I’m looking into a set of used genuine ones to rebuild and make all pretty I’m wondering if I should go for vented?
While I’m overhauling is it considered an upgrade to fit vented discs? Pros and cons
Also I’m wondering what defenders came with vented discs? 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #797338 8th Oct 2019 9:39pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
I’d go vented all the way much less brake fade if you are a little excitable with the accelerator
Lucari solutions have genuine complete sets available for circa £125
You can buy a full set of stainless pistons and seals from optimil
I’m in the process of rebuilding the ones I just brought from them with the stainless pistons
 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #797341 8th Oct 2019 9:52pm
A 2010 2.4 USW should have vented front discs anyway.
Post #797362 9th Oct 2019 8:38am
