Home > Wheels & Tyres > Dynabeads in rear tyres?
Page 1 of 4 1234>
Co1
Is this a stupid question? Does anyone bother with the rears??
Post #797143 7th Oct 2019 5:07pm
rallysteve
Yes, why wouldn't you want to have balanced rear tyres? 02' 110 TD5 Double Cab Rebuild Thread
Post #797145 7th Oct 2019 5:20pm
As above, why on earth wouldn't you balance the rears?
All of mine have beads in, quite a lot of beads in fact.
Post #797148 7th Oct 2019 5:33pm
Co1
Hence the question; wasn't sure so asked. All tyres are balanced as best they can be, but the big mud tyres get a slight wobble at 55mph+ so thought sticking some beads in the front would sort it.
Post #797150 7th Oct 2019 5:44pm
Why not do them all? $W33T $0U7H3RN $UG4R
Post #797156 7th Oct 2019 6:00pm
Co1
‘Cos I only ordered enough to do two!! Embarassed
Post #797163 7th Oct 2019 6:35pm
Ah. Put them in the front, then. For info I found I needed approx 8oz (225g) of beads in each of my 255/85 BFG KM2s, so you may need more than you expect.
Post #797165 7th Oct 2019 7:10pm
Co1
Cheers Blackwolf. I’m probably being a bit OCD about it as it is only very slight, but it will annoy me if I don’t sort it. I’ll see how it is after and order the rears if necessary.
Post #797166 7th Oct 2019 7:14pm
I have standard recommendation Dynabead weight in my tyres on which are also 255/85 too. But they have been balance and have weights fitted too though. I’m not sure if Blackwolf does have weights on his as well or not but I’d go for recommended weight first. If that doesn’t solve it then go up to the weight BW mentioned. Mines been fine so far, at higher speeds they are smooth as silk. $W33T $0U7H3RN $UG4R
Post #797173 7th Oct 2019 7:42pm
Co1
Thumbs Up
Post #797180 7th Oct 2019 8:23pm
No weights on mine, just beads because (1) I hate weights for various reasons* and (2) my local tyre dealer can't mount Blindos on his balancing machine!
* Reasons why I hate weights:-
  • they look hideous even if not on the outside of the wheel
  • they don't self adjust as the tyre wears (important with mud tyres)
  • they have been known to fall off
  • they make it difficult to clean the wheels
Post #797227 8th Oct 2019 7:58am
Co1
Cheers blackwolf. Good to know they get good reviews.
Post #797294 8th Oct 2019 5:14pm
The only reason I have weights on is because they were fitted before the beads. If it wasn’t for that I’d have just gone with the beads like BW did. $W33T $0U7H3RN $UG4R
Post #797306 8th Oct 2019 6:06pm
Co1
Well, I put 6oz in each and can’t really tell the difference. I still get a wobble at 55-60. Just passed MOT a few weeks ago so I’m pretty confident and all the steering and bearings are ok. I’m on Goodyear MTRs, is it worth sticking a few more oz in each?
Post #797670 11th Oct 2019 5:06am
geobloke
Re: Dynabeads in rear tyres?
Even more stupid question for those with these fitted. Do you hear the beads at all?
Post #797691 11th Oct 2019 7:25am
Page 1 of 4 1234>
