Home > Puma (Tdci) > TDCi heater control valve options |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 209 |
Here is a video of swapping it out if anyone is interested
29th Sep 2019 2:20pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1224 |
I like the coolant dipstick in the video, I wonder if it is home made or available? 1984 One-Ten CSW
2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
29th Sep 2019 6:08pm |
Home made, very easy from a piece of sheet metal.
29th Sep 2019 6:31pm |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2048 |
That’s a very comprehensive video Pinky. Thanks for posting it.
Now need to source some pipe clamps ! I was hoping that as the pipes look higher than the coolant tank top level I would not need to clamp them off, but seems I must to avoid a lot off coolant loss. As for the coolant dipstick, Great little gadget , would save using my index finger which seems the perfect length. The video said home made so I guess I will fabricate one just like it. |
29th Sep 2019 6:44pm |
Thanks I will give it a go. Sorry i did not pick up the home made mention in the video, had to watch with the volume down......still better entertainment than strictly come dancing which Im suffering at the moment 1984 One-Ten CSW 2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
29th Sep 2019 7:01pm |
yes |
29th Sep 2019 7:07pm |
Just purchased the clamps. Sealey vso301 , a set of 4 clamps at £8.45 inc postage from FFX tools. At that price I purchased 2 sets so I had 4 of the largest clamps. The smaller ones will be good for brake pipes. The clamps look well made and look like they will spread the pressure on the pipes so not to damage them. Plus being screw clamps they are compact and you can fine adjust clamp pressure easily.
Valves arrive monday so next weekend will change valve over. The video posted looks comprehensive, but if I find I come across something different in change over I will post on that with some pictures. |
5th Oct 2019 6:26pm |
As an update, when changing my EGR I had to remove the heater control valve to gain access to the EGR coolant pipes , bolts, nuts and studs. If the engine is cold and you have the valve switched to cold there is minimum coolant loss, a small cup will catch it. So really don’t need to clamp the coolant hoses when changing out the heater valve in my experience.
Also for topping up get a litre of genuine Orange coloured concentrated coolant from a dealer. It’s not that expensive and you are assured on compatibility with current coolant. Also use de-ionised water to dilute. Cheap from supermarkets as used by people in irons to stop them furring up. |
8th Nov 2020 11:30am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
Anyone fitted this? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
6th Apr 2023 11:54am |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 |
In principle there is nothing against it, but you have to ask for the diameter of the adjustment so that the original Bowden cable has the same path.
6th Apr 2023 3:13pm |
^ excuse my ignorance, but would you mind explaining this like you would to a 5-yr old? --
6th Apr 2023 3:47pm |
Of course. The original adjustment is determined by the path of the rotary knob translated via the Bowden-cable. If the dimensions of the alternative control valve are not correct, it either remains open or (if too short) cannot be turned to the end. This means that the "adjustment travel" must be identical. HTH!
6th Apr 2023 7:19pm |
these are the specs, how does one determine the adjustment travel? Specification Metric Imperial & Other Hose Size ∅ 16mm ∅ 5/8" Post Size ∅ 4.5mm ∅ 0.18" Min Temperature -40 °C -40 °F Max Temperature 110 °C 230 °F Pressure Limit 3 BAR (Gauge) 43.5 PSI (Gauge) Construction Zinc Plated Steel Cable Required Bowden Cable with Looped End Cable Movement 30mm Operation Pull to Bypass Part Number 149-CDB-560 -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
7th Apr 2023 7:35am |
piechipsandpeas Member Since: 12 May 2021 Location: Albany, Western Australia Posts: 216 |
Hey Naks
Regarding the adjustment travel. I have measured my original LR control valve and got the following dimensions from end of cable outer sheath to start of the ferrule that attached the cable to the valve: Cold position (fully closed) = 38mm Hot position (fully open) = 11mm Total adjustment travel = 27mm (the blue and green cable ties are there to stop the end of the cable outer from flexing which can prevent the valve from fully closing, resulting in always having hot air blowing out of the vents). Andy Fully closed position Click image to enlarge Fully open position Click image to enlarge |
7th Apr 2023 1:05pm |
