excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
Front and rear diff oils done
Gearbox oil done Transfer case done.(considered the buzz gun to remove the filler plug, but in the end brute force did it) Oil change day cut short by the need for a blood test. More of the same oil fun tomorrow. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Engine oil/filter/rotor filter replaced. Fuel filter replaced and a tip run done with old oils & filters.
6129 miles since last oil change and bang on 6 months 21/03 and 21/09 ![]() Regards John M0VAZ Econet Station 48 no clock |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3694 ![]() ![]() ![]() |
Have a loaner at the moment as my 90 is in warranty work in the paint (Ripon Land Rover are excellent
![]() ![]() Click image to enlarge |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Finally, properly fitted the Skycamp today. Took all day what PITA!
![]() Click image to enlarge ![]() Click image to enlarge James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3348 ![]() ![]() ![]() |
Looks like it was worth it though. Very nice mate.
Sulisuli Member Since: 30 Oct 2016 Location: South west Posts: 4799 ![]() ![]() ![]() |
I’m liking that james
![]() 2008 SVX 90 2000 XS TD5 90 |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1844 ![]() ![]() ![]() |
Gave in to pressure from SWMBO and took an old sofa to the tip. Excuse to use the sankey though
![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17598 ![]() ![]() ![]() |
I can't get into my local tip in the Defender, and I certainly would be allowed to take a Sankey in! You're lucky if you can at yours!
I was reprimanded last time I took a load of rubbish down in the Disco (allowed in because it's not "commercial") because I was pouring a 5 gallon drum of waste oil into the tank. Apparently any container larger than 4 litres now means it must be trade waste. What a nonsense! No wonder there's fly tipping everywhere. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
4L 🤣 That’s all a couple of mowers would hold.
Wouldn’t a garage take it tip it out and give you the container back? I think there is a disposal / enviro fee though. But I’d rather that than £80k + a year councillors getting funded by it. Around here they are idiots too regarding what you can and can’t supposedly do. As said. No wonder there is flu tipping. And of course you guessed it, they’ll try and push that onto farmers too. Chillin In The Backwoods🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
We see more and more oils, petrols and paints being poured into the sewer system, very unpleasant because of the risk of explosions and gases, all because you can’t take anymore than 4 litres to the municipal tip
I must be lucky. My local tip allows me in with my DCPU and 5m trailer, usually loaded to the gunwales with garden waste. I have taken waste oil on a couple of occasions and that required a separate log entry of my vehicle reg, even though the oil was from a ride on mower? Actually, I also took a 2,500 litre heating oil tank to the tip on the trailer. Local council appear to know the issues a largely rural community have and fly tipping is a costly issue. |
Also on my tip run, I disposed of oils. I could only just lift the container with the oils but luckily for me, the waste oil container is before the main gate control for the tip. 1999 Defender TD5 110
Our tips used to be a nightmare, but over the last few years seem much better. Apart from helping to sort the waste properly they don't seem to mind anything being taken now. James
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2186 ![]() ![]() ![]() |
Proper plonkers around here.......
