Home > Td5 > Td5 Coolant Bleeding
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
I’ve just replaced the heater inlet pipe running above the exhaust manifold of the Td5. I actually managed to not lose too much coolant! I’m now trying to figure out how best to bleed the system as obviously some air is going to have been introduced into the heater hoses. I have done as the RAVE manual suggests. I’ve set the temperature setting to hot in the cab and opened up the bleed screw on the top hose. An instant strong flow of coolant came out. I can’t imagine it is actually that simple? Is there a way of checking there is no air in the heater matrix etc?
Cheers!
 Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #792501 12th Sep 2019 3:56pm
I think it really is that simple! Thumbs Up
Post #792509 12th Sep 2019 4:27pm
BaronDefenders
Well perfect! I’m glad for once a job has gone to plan! Laughing Charlie
2002 Td5 90 (SOLD)
Post #792513 12th Sep 2019 4:33pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
You can loosen off the jubilee clip in the return pipe from the heater matrix and check for air from there, I have a nice ground down screwdriver for this job so as not to damage the pipe when I slide it between the rubber pipe and rigid plastic pipe, normally get a few bubbles of air out, saying that if you are getting nice warm/hot air from your vents you should be fine. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #792647 12th Sep 2019 10:32pm
BaronDefenders
Ah OK, thanks for that tip Thumbs Up I’m getting lovely hot air at the moment so I’ll just keep an eye on it for the minute! Charlie
2002 Td5 90 (SOLD)
Post #792679 13th Sep 2019 7:44am
