![]() | Home > Td5 > Td5 Coolant Bleeding |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17726 ![]() ![]() ![]() |
I think it really is that simple!
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 917 ![]() ![]() ![]() |
Well perfect! I’m glad for once a job has gone to plan!
![]() 1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
You can loosen off the jubilee clip in the return pipe from the heater matrix and check for air from there, I have a nice ground down screwdriver for this job so as not to damage the pipe when I slide it between the rubber pipe and rigid plastic pipe, normally get a few bubbles of air out, saying that if you are getting nice warm/hot air from your vents you should be fine. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
Ah OK, thanks for that tip
