![]() | Home > Puma (Tdci) > MY2011/2012 Recall Action P047/048 Front Axle Case |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4748 ![]() ![]() |
The only way that Land Rover could be "persuaded" to address this issue is if during the press briefing for the launch for the "new Defender" the Solihull man expounds on the advantages of the new front suspension system over the old fashioned live beam axle championed by Land Rover on the previous model i.e. existing model.
If a journalist then quips "Then that will do away with the dangerous fault in the old live beam axle with the axle flange welding issue." Land Rover would not want their launch to be tainted with such an issue. Now if you could get a journalist to contact Land Rover before the launch and raising this issue, they might address it to stop it rearing it's ugly head at the launch of the new model....if it ever materialises. 1982 88" 2.25 diesel 1992 110 200tdi csw -Zikali 2008 110 2.4 tdci csw-Zulu 2011 110 2.4 tdci csw-Masai |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4251 ![]() ![]() ![]() |
Unfortunately, I can’t speak the lingo, but it looks like you’ve used the the LR safety bracket things to actually strengthen axle to prevent it failing in the first place, rather than just stop if falling off when if does break.
MarcoLauretano Member Since: 07 Apr 2015 Location: Avellino Posts: 23 ![]() ![]() ![]() |
Yes, the change I published serves to prevent welding from breaking.
Thank you. |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 672 ![]() ![]() ![]() |
Wow - that is impressive engineering - especially making the offset pieces for welding in.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17633 ![]() ![]() ![]() |
Very nicely done, but.....
.... I have to wonder if the work involved wasn't actually more that the work needed to beef up and reinforce the dodgy weld between the axle and flange. The most important thing is that is has sorted the problem and gives peace of mind. It is certainly a fine example of first class engineering. I find it hugely reassuring just to know that my hubs can't pert company with the axle after I fitted the brackets, and still think JLR's attitude to this particular issue is shockingly cavalier. I wonder if the new Defender will be treated with similar disdain. |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
That's all very impressive, but with all that precision, using an angle grinder and drill press to skim down the screw heads made me chuckle. I think I'd probably do that bit with my lathe (of course it helps if you've got a lathe....)
I wonder if the owner does actually eat his dinner off that axle. I'll bet it was dirtier on the production line! |
If a picture paints a thousand words, the above is the Encyclopaedia Britannica. Great effort. You're a man who takes his work seriously with lots of attention to detail. If that was mine I'd probably spend hours looking at the finished product and forget to drive it! 1982 88" 2.25 diesel
![]() Ecco le ultime foto delle staffe verniciate e montate definitivamente : ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 753 ![]() ![]() ![]() |
Any chance we can get the details of this in english and what materials are needed?
If this is a tad overkill, if I order the brackets, is it a straightforward installation? As blackwolf said, this is a better safe than sorry kind of situation. This is critical where I am right now where independent shops are more capable and reasonable than the local dealer. ![]() ![]() |
Fitting the brackets is very straightforward (although you need to remove the nuts from the radius arm bolts which can be a pain depending upon their condition, and access with tools is not great) and really doesn't take long.
The brackets are also intended not to mask a weld failure since they will allow the tell-tale oil leak, since it would clearly be a bad thing to drive about with a failed weld even with the brackets. Whilst I admire the engineering effort which went into MarcoLauretano's axle it is not something that I personally would do. The brackets may not prevent your axle failing, but they will make it a safe failure, and that amount of engineering would in my view be better spent making the axle case itself stronger. |
Since I'm not sure if my axles are covered in the recall (I suck at trying to figure out if my VIN is covered or not), I want to be sure that the truck is safe as I do take it off road and it is also my daily driver.
I recently dented the front diff cover so was thinking of getting the Gwyn Lewis weld on to make it tougher plus sumo bar gear for the steering as these are most definitely affected by the boulder I ran over trying to escape a flash flood. So yeah, fun. I'm still trying to figure out if that boulder hit anything else under there but it seems a new steering guard (a new plate type is due perhaps?), the steering rods and ends, the ball joint thingie in the rear suspension, and pound the rear right mud guard and the folding step back into shape and place are the most obvious things to work on at the moment. |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1879 ![]() ![]() |
So, would it be reasonable to conclude that the fitting of these two additional brackets would be a good idea as a precaution on a MY16 90 that's done less than 20k miles? Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
I wouldn't drive a Puma without the brackets fitted.
