Home > Maintenance & Modifications > Removing steering wheel
excossack
Tried removing the steering wheel, partly undone the nut and no amount of banging, pulling wiggling, swearing makes it move. Considering a 3 legged puller, TNT or the local garage!
Tips, tricks etc? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #787568 19th Aug 2019 7:23am
If you have access to an assistant, try getting them to give the nut a sharp tap with a hammer (note a tap, don't beat the daylights out of it!) whilst you pull hard on the wheel, sometime that shock of the impact is all it needs.
Some types of LR wheel are drilled and tapped for a puller, most however are not, and unless you have access to a proper old-style steering wheel puller can be a major PITA.
When you do get it off, before refitting it (or whatever you're fitting in its place) put a smear of copperslip on the splines and taper and do not over-tighten the nut, it really doesn't need to be done up ridiculously tight like most people seem to do, since all it does is hold the wheel onto the taper.
Post #787570 19th Aug 2019 7:29am
discomog
Don't use a 3 leg puller. You need a steering wheel puller that utilises the threaded holes in the steering wheel. No doubt someone will be along shortly and be able to give you the manufacturers name, or you could make one up yourself. Alternative is to Google "steering wheel puller".
Blackwolf beat me to it Thumbs Up Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #787571 19th Aug 2019 7:31am
excossack
Thanks both.
There are no threaded holes in the boss for the insertion of bolts to remove it. Sad
Back to sharp taps and wiggling. The wheel is getting removed as there are two cracks through the holes where the screws go through into the boss. 1999 Defender TD5 110
Regards
John M0VAZ
Post #787573 19th Aug 2019 7:55am
This is my concern also as I may need to get mine off sometime. Have you soaked it in penetrating fluid like WD40 the day before?
On a Puma the steering wheel nut is 27NM if memory serves me rightly.
So as Blackwolf mentions that is not overly tight.
But as it is a safety critical item myself personally I would always use WSM torque spec on this. (Some may say that’s fussy, but we all do things differently.)
It is very annoying when what appears to be a simple job often ends up being one of the hardest and very time consuming to boot.
This is often the case, and what appears to be large difficult jobs can be completed, finished and in good time. Rolling Eyes $W33T $0U7H3RN $UG4R
Post #787578 19th Aug 2019 8:49am
excossack wrote:
Thanks both.
The absence of threaded holes on most LR wheels is the reason why you need an old-fashioned steering wheel puller (which unfortunately are both rare and expensive nowadays). These have a hefty padded bifurcated steel ring which goes behind the wheel, and the puller then pulls on the ring. I have a long-discontinued SP version, but similar things are still available - if you have £150 or so to spare:
https://www.lawson-his.co.uk/gedore-802875...ler-1-68-1
Post #787598 19th Aug 2019 10:38am
excossack
Thanks BW. I think I might pop over to the local garage and see if they can assist.
Word of the day: bifurcated 1999 Defender TD5 110
Regards
John M0VAZ
Post #787599 19th Aug 2019 10:42am
Siwynne
Pour a little (loads) boiling water into the boss whilst wriggling banging and pulling.
Obviously don’t sit in the drivers seat whilst doing this. It’s worked for me in the past.
Post #787658 19th Aug 2019 3:02pm
G4UJS
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I had exactly the same problem, took it to a local Land Rover specialist and he had it off in 2 seconds without using any tools.... he just shook it far more than I would of dared!!!!!
Good luck
Rob
Post #787659 19th Aug 2019 3:07pm
And there I was thinking that this technique relied upon the sudden shock loading that you put on the wheel when the boiling water hits your nuts!
Post #787667 19th Aug 2019 3:22pm
NickMc
I agree with Rob put a bit of welly into it and give it a good tug and wiggle (leave the nut on a few threads so it doesn't smack you in the face) don't be scared you'll not break it.
Post #787731 19th Aug 2019 6:12pm
This made me laugh when it shouldn't really. Laughing What's worse is when corrosion sets in on your nut(s) if you've applied boiling water too. Whistle Rolling with laughter
Then you'll certainly need a puller.... Shocked Twisted Evil Rolling with laughter
On a more sensible note. Laughing
It definitely seems to be a case of giving it a bit of welly as Nick mentioned with the nut still slightly threaded on. $W33T $0U7H3RN $UG4R
Post #787796 19th Aug 2019 9:08pm
NickMc
What are you trying to say Steve? when you have problems in life just give it a good tug and wiggle?
Post #787799 19th Aug 2019 9:13pm
excossack
Rubber hammer time. (and avoid hot water on my nuts) 1999 Defender TD5 110
Regards
John M0VAZ
Post #787844 20th Aug 2019 7:52am
Siwynne
Is this an aftermarket or og wheel and boss.
Post #787861 20th Aug 2019 11:21am
