Home > Td5 > Smoking TD5
Roald
Denmark
Smoking TD5
Hello
My 2005 MY defender smokes black when driving, it always smokes right before the turbo boost kicks in.
When the engine is under boost, no black smoke is seen unless it gets full pedal.
As the defender drives very good and with a lot more power than I would expect from a vehicle this heavy with only 122 HP, I was wondering how to find out if it has gotten a remap some time?
I have copied the map file (its has a .bin extension) with my nanocom evolution.
I would like to return it to stock if it has been altered. My fuel mileage is pretty low, even when driving very nice
Regards,
Roald
Post #78707 2nd Jul 2011 1:34pm
A dodgy, or "on its way out" MAF meter can cause a lot of smoking.
Post #78710 2nd Jul 2011 2:44pm
Roald
Denmark
The MAF is new (and the replacement part is an original LR part) and there is no oil in the ECU plug. The injector harness has been changed. The EGR valve has also been eliminated
Post #78725 2nd Jul 2011 5:24pm
landy andy
My Td5 has always smoked since it's remap.
Have got a new remap today and no more smoke, but still got all the poke. So possibly yours has a basic remap. Ask Garry at Alive, he will be able to tell you what you have got.
If you are saying it goes well, it must have some thing, but this may not be a good thing, unless done properly.
Andy
Post #80480 15th Jul 2011 8:54pm
Roald
Denmark
Andy
Anybody knows where I can get a stock map which the nanocom can upload?
Post #80617 17th Jul 2011 7:23am
Glynparry25
Might be an idea to check the turbo. Very similar symptons to a turbo with seals that are on their way out.
Glyn Dog Sheep
Post #80635 17th Jul 2011 9:52am
If you use the Nanocom software (you can download it from their site) it comes with all the standard tune files for defender/disco Td5 for Europe, UK, Japan and RoW
Post #80714 17th Jul 2011 8:27pm
Roald
Denmark
Glyn Dog Sheep
Yes, I'll do that too. How do I check the seals? Wouldnt the engine use engine oil if the seals are shot?
I found out that the PC software that came with my nanocom actually contained different stock map files so I uploaded a stock map for a defender 90" ROW NNN500020 ECU. My ECU originally contained a map for a 110" Defender NNN500020 ECU even as my ECU has this number nnw501290 so I guess it must have been changed at some point.
After the upload the defender lost a little bottomend and maybe a little on the topend, but not much. Maximum turbo pressure seems not to go over 1.05 bar now
It still smoked on startup (very black smoke). I did'nt see much smoke while driving but I'm not sure that it helped as I did not test drive it for long.
Post #80717 17th Jul 2011 8:45pm
Roald
Denmark
Thanks for that, I overlooked your post yesterday. Will there be any advantages with a newer map as my defender is from 2005 and the nanocom files are from 2002?
After a longer drive today I can see that 90% of the smoke is gone. It only smokes a little now when its really pulling at low rpm. No big clouds of black smoke between gearshift anymore.
...the downside is that it probably has lost 30% power Smile
Post #80796 18th Jul 2011 2:19pm
Glynparry25
Sounds like you have found the fault but to check a turbo over:
1. Take off the inlet pipe (from Air box), check:
a. All the blades are present and intact.
b. Give the center ring a wiggle. A little movement is OK.
2. Take off the exit pipe (to intercooler), check:
a. For oil. There is a chance that there will be a little but lots id bad.
Now all you need is a good reliable map Smile
Glyn Dog Sheep
Post #80819 18th Jul 2011 4:41pm
bell-auto-services
Roald if you send me the read map from your car I will take a look at it if you wish.
Pete
Post #80820 18th Jul 2011 4:55pm
Roald
Denmark
Pete
Thanks, that's a great offer Very Happy
But I'm not sure that I actually got the read map, I downloaded the original (old) map two times (with different file names) before uploading the stock one from the nanocom map wizard, but when I plugged the SD-card into the computer I only got one file named 'TD5ENG.BIN' size 128 Kbytes? I was expecting a .map file.
I've uploaded the file to a free upload site at this address
http://gratisupload.dk/vis/62913/ (click the yellow box 'DOWNLOAD FIL')
Here is the info from the nanocom (the original old 'smoking' map)
Post #80890 18th Jul 2011 8:26pm
bell-auto-services
Hi
Im not sure the file is correct, but ill take a look.
pete
Post #80893 18th Jul 2011 8:31pm
