Home > Maintenance & Modifications > Caster/camber sleeves
Naks
Hi everyone,
In order to cure a negative caster angle on the front left, the wheel alignment specialist recommended we fit one of these caster sleeves, made by SPC: https://www.spcalignment.com/instructions/88901-INS_WEB.pdf
Seeing I have a friend going to the UK soon, does anyone know where I can find this type of kit in the UK?
Thanks --
Post #787010 15th Aug 2019 4:27pm
Bluest
I've not seen these before, are the an alternative to caster correction bushes? 2007 110 TDCi Station Wagon XS
Post #787028 15th Aug 2019 5:16pm
Naks
Indeed.
Whereas bushes must be installed in a set, this allows you to tweak the castor on one side of the axle, and this company makes them in small increments, from 1.2 to 2.2 degrees. --
Post #787032 15th Aug 2019 5:25pm
