![]() | Home > Maintenance & Modifications > Caster/camber sleeves |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2660 ![]() ![]() ![]() |
Hi everyone,
In order to cure a negative caster angle on the front left, the wheel alignment specialist recommended we fit one of these caster sleeves, made by SPC: https://www.spcalignment.com/instructions/88901-INS_WEB.pdf ![]() Seeing I have a friend going to the UK soon, does anyone know where I can find this type of kit in the UK? Thanks -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4230 ![]() ![]() ![]() |
I've not seen these before, are the an alternative to caster correction bushes? 2007 110 TDCi Station Wagon XS
Indeed.
Whereas bushes must be installed in a set, this allows you to tweak the castor on one side of the axle, and this company makes them in small increments, from 1.2 to 2.2 degrees. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
