![]() | Home > Puma (Tdci) > "Kangaroo" impression from cold (2.2 2014) |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3654 ![]() ![]() ![]() |
if you do a search there is a post about this and BAS and others can tune it out DEFENDER 90 TDCI XS,
UtilityTruck Member Since: 09 Jan 2014 Location: Oxford Posts: 463 ![]() ![]() |
..but it shouldn’t be there. Mine (2014 2.2) doesn’t do it, or rather it only does it very very infrequently. Perhaps 5 times in 60k?
Are you sure your servicing and maintenance is up to date? No fault codes logged? 2014 Keswick Utility 2.2 |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Thanks folks. It's been serviced annually, initially by Land Rover and now by my local garage. I'll have a chat with them about fault codes and see if they can help.
I must admit I have been considering a re-map, but my insurance is (relatively) so cheap, I don't want to end up paying out a load more for it. |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
When I used to get kangerooing it was at anytime, not just when cold. It used to just be when going fast in 1st then lifting off the power.
Remap transforms the drive, got rid of 95% of kangerooing, and only added £30 to insurance. Highly recommend. James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Dragging my old thread back up, I've got the BAS 170 remap, and it initially got rid of the problem (please see post 1), but for some reason, it's now coming back, as originally, only from cold and only for a minute or two.
Can anyone offer any suggestions as to what to check please? There are no fault codes logged. |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 550 ![]() ![]() ![]() |
The engine management adapts itsself i.e. the CPU is capable of learning and changing the paramètres within a certain range.
Jak Member Since: 08 Nov 2012 Location: Home Posts: 4 ![]() ![]() ![]() |
Hi,
I had the same thing (Puma 2.4), that has improved after the BAS mapping, it is now barely noticeable. |
As I mentioned above, it improved after the BAS 170 remap but has now come back.
Does anyone have any information about what causes it in the first place please? |
