Home > Puma (Tdci) > Front driver side brake |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 529 |
Stone jammed in caliper?. Pop caliper off and see if it frees up.
25th Jun 2019 6:30pm |
claydiggermud Member Since: 11 Jul 2015 Location: west country Posts: 86 |
Many thanks for your reply I shall have a look in the morning
25th Jun 2019 6:32pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
It could be a seized piston also. See if you can push the pistons back into the caliper body
25th Jun 2019 6:54pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
front flexible brake pipe failed internally
edit - scrub that as its so new and you use it in the mud most likely a caliper problem as others have said DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
25th Jun 2019 8:10pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20367 |
If you don't find anything with the brakes, then possibly wheel bearing. $W33T $0U7H3RN $UG4R
25th Jun 2019 8:32pm |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 75 |
I'd be more inclined to think it's the wheel bearing. if it's been over torqued or has a lack of grease they will overheat. When they go they either shatter or fuse together with the heat.
26th Jun 2019 8:45am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5700 |
Wheel bearing.
26th Jun 2019 7:40pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
calliper bolt fell out and calliper locking on inside of wheel?
Keith |
27th Jun 2019 9:07pm |
All gone quiet, did you find the cause?
28th Jun 2019 5:47pm |
