![]() | Home > Puma (Tdci) > Front driver side brake |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 547 ![]() ![]() |
Stone jammed in caliper?. Pop caliper off and see if it frees up.
claydiggermud Member Since: 11 Jul 2015 Location: west country Posts: 86 ![]() ![]() ![]() |
Many thanks for your reply I shall have a look in the morning
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 ![]() ![]() |
It could be a seized piston also. See if you can push the pistons back into the caliper body
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3665 ![]() ![]() ![]() |
front flexible brake pipe failed internally
edit - scrub that as its so new and you use it in the mud most likely a caliper problem as others have said DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20765 ![]() ![]() |
If you don't find anything with the brakes, then possibly wheel bearing. WeWillWinπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
neon1991 Member Since: 26 Mar 2018 Location: Colchester Posts: 100 ![]() ![]() ![]() |
I'd be more inclined to think it's the wheel bearing. if it's been over torqued or has a lack of grease they will overheat. When they go they either shatter or fuse together with the heat.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5872 ![]() ![]() |
Wheel bearing.
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1853 ![]() ![]() ![]() |
calliper bolt fell out and calliper locking on inside of wheel?
Keith |
All gone quiet, did you find the cause?
