Home > Puma (Tdci) > Front driver side brake
claydiggermud
United Kingdom 2014 Defender 90 Puma 2.2 HT Tamar Blue
Hi , driving home and my front wheel locked up completely for no reason could not move the Landy had to get recovered.
Front drive shaft appears ok and moving freely but the disc is very hard to move any idears .
Many thanks in advance
Post #778977 25th Jun 2019 5:44pm
htb2
Wales
Stone jammed in caliper?. Pop caliper off and see if it frees up.
Post #778983 25th Jun 2019 6:30pm
claydiggermud
Many thanks for your reply I shall have a look in the morning Thumbs Up
Post #778984 25th Jun 2019 6:32pm
williamthedog
It could be a seized piston also. See if you can push the pistons back into the caliper body Thumbs Up
Post #778986 25th Jun 2019 6:54pm
LR90XS2011
front flexible brake pipe failed internally
edit - scrub that as its so new and you use it in the mud most likely a caliper problem as others have said DEFENDER 90 TDCI XS,
Post #779003 25th Jun 2019 8:10pm
If you don't find anything with the brakes, then possibly wheel bearing. $W33T $0U7H3RN $UG4R
Post #779007 25th Jun 2019 8:32pm
neon1991
United Kingdom 2014 Defender 110 Puma 2.4 USW Firenze Red
I'd be more inclined to think it's the wheel bearing. if it's been over torqued or has a lack of grease they will overheat. When they go they either shatter or fuse together with the heat.
Post #779062 26th Jun 2019 8:45am
landy andy
Wheel bearing.
Post #779154 26th Jun 2019 7:40pm
ickle
calliper bolt fell out and calliper locking on inside of wheel?
Keith
Post #779293 27th Jun 2019 9:07pm
htb2
Wales
All gone quiet, did you find the cause?
Post #779415 28th Jun 2019 5:47pm
