Home > Maintenance & Modifications > Rear shock absorber replacement 110 2009 |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4209 |
Those cups/washers are on the wrong way round. The convex side should be against the bush. 2007 110 TDCi Station Wagon XS
4th Jun 2019 5:07pm |
LR110 BG Member Since: 02 Apr 2019 Location: Wiltshire Posts: 16 |
OK thank you will take note when I try to replace the bushes. I don’t suppose you could recommend what kind of bushes these are and what to replace them with?
5th Jun 2019 9:38pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
Message Dan @ Duckworth LR on here. He will guide you to the correct P/N.
And agree that those washer cups are the opposite orientation to how they should be. Finally the nut does have a Torque spec mentioned in the WSM. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
5th Jun 2019 10:03pm |
I swapped from OE to SuperPro lower bushes just because the lower OE ones seem to last about two minutes. 2007 110 TDCi Station Wagon XS
6th Jun 2019 5:39am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17372 |
I usually have to replace the rear bushes annually, just before the MOT test, which for me that is about 15k to 20k miles. I use genuine bushes as aftermarket ones seem to be even less durable than genuine.
I don't know why a Puma 110 seems to eat these bushes at such a rate. |
6th Jun 2019 7:43am |
