Home > Td5 > another strange starting problem
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
unlock the car with the remote put the ignition on and all the dash lights come on fuel pump runs but when I turn the key to start the car nothing happens, let the car roll back 2-3 feet and it starts as normal, this has happened twice I have checked all the earths and the relays under the seat, any ideas. nobody is perfect but being Scottish is a start
Post #775146 27th May 2019 8:04am
landy andy
Starter solenoid
Post #775147 27th May 2019 8:09am
OsloBlue
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Single click = Solonoid
Multiple clicks = Voltage I'm on IG: https://www.instagram.com/osloblue42/
Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html
Post #775163 27th May 2019 10:05am
T140
there is no click from the starter nobody is perfect but being Scottish is a start
Post #775179 27th May 2019 12:21pm
htb2
Wales
Try a positive feed from battery direct to starter motor spade terminal, to check if starter motor or wiring
Post #775180 27th May 2019 12:32pm
dorsetsmith
age of starting battery ? and have you had it tested
Post #775184 27th May 2019 1:47pm
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
my bets are on a rusty crusty earth
Post #775186 27th May 2019 2:00pm
roel
Take the starter out, clean it and put new contacts in the soloniod. Also clean de inside off the starter gearbox and put new grease there. It will run a lot better. Roel
2003 90 Td5 (2009-now)
Post #775207 27th May 2019 6:49pm
T140
hopefully got it fixed, the starter wire on the solenoid was a loose fit and grubby, cleaned the terminal on the starter and put a new crimp on and it has been ok since, what i dont get is why when i let it roll back it would start. nobody is perfect but being Scottish is a start
Post #775446 29th May 2019 6:14pm
