![]() | Home > Td5 > another strange starting problem |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5866 ![]() ![]() |
Starter solenoid
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 825 ![]() ![]() ![]() |
Single click = Solonoid
Multiple clicks = Voltage I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html ![]() |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 177 ![]() ![]() ![]() |
there is no click from the starter nobody is perfect but being Scottish is a start
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 546 ![]() ![]() |
Try a positive feed from battery direct to starter motor spade terminal, to check if starter motor or wiring
age of starting battery ? and have you had it tested
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 ![]() ![]() ![]() |
my bets are on a rusty crusty earth
Take the starter out, clean it and put new contacts in the soloniod. Also clean de inside off the starter gearbox and put new grease there. It will run a lot better. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
hopefully got it fixed, the starter wire on the solenoid was a loose fit and grubby, cleaned the terminal on the starter and put a new crimp on and it has been ok since, what i dont get is why when i let it roll back it would start. nobody is perfect but being Scottish is a start
