Home > Td5 > another strange starting problem |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5720 |
Starter solenoid
27th May 2019 7:09am |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 823 |
Single click = Solonoid
Multiple clicks = Voltage I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
27th May 2019 9:05am |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 173 |
there is no click from the starter nobody is perfect but being Scottish is a start
27th May 2019 11:21am |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 530 |
Try a positive feed from battery direct to starter motor spade terminal, to check if starter motor or wiring
27th May 2019 11:32am |
age of starting battery ? and have you had it tested
27th May 2019 12:47pm |
windy81 Member Since: 14 Mar 2018 Location: North Wales Posts: 311 |
my bets are on a rusty crusty earth
27th May 2019 1:00pm |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Take the starter out, clean it and put new contacts in the soloniod. Also clean de inside off the starter gearbox and put new grease there. It will run a lot better. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
27th May 2019 5:49pm |
hopefully got it fixed, the starter wire on the solenoid was a loose fit and grubby, cleaned the terminal on the starter and put a new crimp on and it has been ok since, what i dont get is why when i let it roll back it would start. nobody is perfect but being Scottish is a start
29th May 2019 5:14pm |
