Home > Puma (Tdci) > Clonkly noises |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
pos back lash in the propshafts etc as the wheels are turning the shafts and not vice versa. 2.4 90 XS
24th Jun 2011 7:10am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Hand brake incorrectly adjusted is common as well. So next time as you coast to a stop gently (i mean gently) with the button pressed in drag the hand brake and see if the noise disappears. Original Member Pie n Pea Club.
110 HCPU Tipper |
24th Jun 2011 7:32am |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1579 |
I thought prop or handbrake. Was worried it might be clutch. I'll get him to try the handbrake.
24th Jun 2011 8:12am |
Nellie Member Since: 08 Jan 2011 Location: Deep in Lincolnshire Posts: 54 |
We have the same noise under the same conditions - will also try the handbrake
24th Jun 2011 2:10pm |
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 |
Seems a common problem, on newish defenders with the handbrake shoes binding, once it has got a little warm. There are quite a few posts about this, and the symptoms sound exactly the same. |
24th Jun 2011 5:33pm |
Blaserman Member Since: 23 Sep 2008 Location: Herefordshire Posts: 46 |
Mines been doing that!
So far its had 3 rear diffs, a new handbrake drum, a new clutch, 2 rear half shafts and 2 new drive flanges. Its almost cured!!!!! When coasting pull the handbrake up slightly if you hear a machine gun style knocking the handbrake wants backing off a bit. Failing that the clutch seemed to be the main problem on mine. |
30th Jun 2011 7:41am |
