![]() | Home > Puma (Tdci) > Clonkly noises |
pos back lash in the propshafts etc as the wheels are turning the shafts and not vice versa. 2.4 90 XS
Hand brake incorrectly adjusted is common as well. So next time as you coast to a stop gently (i mean gently) with the button pressed in drag the hand brake and see if the noise disappears. Original Member Pie n Pea Club.
110 HCPU Tipper |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1591 ![]() ![]() ![]() |
I thought prop or handbrake. Was worried it might be clutch. I'll get him to try the handbrake.
Nellie Member Since: 08 Jan 2011 Location: Deep in Lincolnshire Posts: 54 ![]() ![]() ![]() |
We have the same noise under the same conditions - will also try the handbrake
Matt Member Since: 28 Feb 2011 Location: Aylesbury, Bucks Posts: 180 ![]() ![]() ![]() |
Seems a common problem, on newish defenders with the handbrake shoes binding, once it has got a little warm. There are quite a few posts about this, and the symptoms sound exactly the same. ![]() |
Blaserman Member Since: 23 Sep 2008 Location: Herefordshire Posts: 46 ![]() ![]() ![]() |
Mines been doing that!
So far its had 3 rear diffs, a new handbrake drum, a new clutch, 2 rear half shafts and 2 new drive flanges. Its almost cured!!!!! When coasting pull the handbrake up slightly if you hear a machine gun style knocking the handbrake wants backing off a bit. Failing that the clutch seemed to be the main problem on mine. |
