Home > In Car Electronics > Reversing Camera Auto Switch on |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 |
Hi. Don’t have a Pioneer one but an alpine headunit. But look in the wiring diagram of the headunit. Mine has a separate input wire from the gearbox, to identify wheter reverse is engaged. If i engage reverse the reverse camera is automatically displayed. a defender from 1984 pretending to be a puma with a touch of Range Rover
4th May 2019 11:26am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20382 |
As above, and possibly assisted with settings on the HU it’s self $W33T $0U7H3RN $UG4R
4th May 2019 11:33am |
buckers19 Member Since: 02 Jan 2018 Location: London Posts: 93 |
Thanks for both of your replies. I will investigate this. Instagram.com/mattbuckley19
4th May 2019 11:36am |
How did you manage to get a wire from the gearbox switch to the HU? I can’t seem to find any obvious path. Instagram.com/mattbuckley19
4th May 2019 2:49pm |
Under the gearbox there is a switch. You can trace back the wire from there. a defender from 1984 pretending to be a puma with a touch of Range Rover
4th May 2019 2:51pm |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 183 |
Hi could you use the live to the reverse light to feed the camera
4th May 2019 4:39pm |
I’am a semi professional on wiring but as i remembered it: the wire from the clutch Goes back to the fuse box and there you can piggy back the signal. There’s the start of the wire to the reverse light as well. a defender from 1984 pretending to be a puma with a touch of Range Rover
4th May 2019 5:18pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Yes. You can get video cable with an integral power cable. With tails both ends. I have one in mine so the reverse light triggers the headunit to switch automatically. Only have to run one cable then but does both jobs. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
4th May 2019 9:03pm |
Kent_keith Member Since: 01 Jun 2014 Location: Kent Posts: 388 |
Could I ask what camera you have, and where it’s mounted? 2005 TD5 90 CSW XS
8th May 2019 10:16am |
Hi I have a Pioneer ND-BC6 to go with my Pioneer F60 DAB head unit, which has been installed for about a year now, haven't installed the camera yet
8th May 2019 11:28am |
I’ve seen reversing cameras up high replacing the back screen washer position then that is moved lower down, seems a good place. 2005 TD5 90 CSW XS
8th May 2019 1:45pm |
Depending on desired use.
Mine overview when backing up. Camera high up next to the washer. If you want it to couple trailers i would put in the recess of your rear member. Seen a lot of those as well. a defender from 1984 pretending to be a puma with a touch of Range Rover |
9th May 2019 10:05am |
