Home > In Car Electronics > Reversing Camera Auto Switch on
buckers19
1993 Defender 90 300 Tdi CSW Barolo Black
Appreciate this may be a very niche question but: I have just installed a Pioneer Z7100DAB HU and reversing camera. The camera is powered from the reversing light so both come on together. Is there a way to display the reversing camera image whenever its switched on (i.e. I am reversing). Currently I have to select the camera in the input list which is a bit of a faff. Instagram.com/mattbuckley19
Post #771490 4th May 2019 11:04am
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Hi. Don’t have a Pioneer one but an alpine headunit. But look in the wiring diagram of the headunit. Mine has a separate input wire from the gearbox, to identify wheter reverse is engaged. If i engage reverse the reverse camera is automatically displayed. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771493 4th May 2019 11:26am
As above, and possibly assisted with settings on the HU it’s self KEEP CALM AND Drill ON
Post #771496 4th May 2019 11:33am
buckers19
Thanks for both of your replies. I will investigate this. Instagram.com/mattbuckley19
Post #771498 4th May 2019 11:36am
buckers19
How did you manage to get a wire from the gearbox switch to the HU? I can’t seem to find any obvious path. Instagram.com/mattbuckley19
Post #771515 4th May 2019 2:49pm
Tdi4
Under the gearbox there is a switch. You can trace back the wire from there. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771516 4th May 2019 2:51pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
reverse camera
Hi could you use the live to the reverse light to feed the camera
Post #771529 4th May 2019 4:39pm
Tdi4
I’am a semi professional Laughing on wiring but as i remembered it: the wire from the clutch Goes back to the fuse box and there you can piggy back the signal. There’s the start of the wire to the reverse light as well. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #771533 4th May 2019 5:18pm
Roy5695
Re: reverse camera
Yes. You can get video cable with an integral power cable. With tails both ends. I have one in mine so the reverse light triggers the headunit to switch automatically. Only have to run one cable then but does both jobs. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #771566 4th May 2019 9:03pm
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
Could I ask what camera you have, and where it’s mounted? 2005 TD5 90 CSW XS
Post #772070 8th May 2019 10:16am
Tegner
reversing camera
Hi I have a Pioneer ND-BC6 to go with my Pioneer F60 DAB head unit, which has been installed for about a year now, haven't installed the camera yet
Post #772088 8th May 2019 11:28am
Kent_keith
I’ve seen reversing cameras up high replacing the back screen washer position then that is moved lower down, seems a good place. 2005 TD5 90 CSW XS
Post #772113 8th May 2019 1:45pm
Tdi4
Depending on desired use.
Mine overview when backing up. Camera high up next to the washer.
If you want it to couple trailers i would put in the recess of your rear member. Seen a lot of those as well. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #772247 9th May 2019 10:05am
