Home > Td5 > Td5 in car spares recommendations?
benniferj
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
Hey all
So I've had my 52 plate TD5 110 since Jan now. I've tackled a really good bunch of tasks on it - such as re bushing it, remapping, bit of engine servicing, oils, filters, belt etc. I'm at the point where I'll be happy to take it on some real long distance trips - it's got a roof tent after all, better use it!
So what bits are good for sticking in a TD5 spares kit? I'm used to my 200tdi 90 - what things are useful to carry to 'get out of jail' on a TD5? So far, in the boot is: Drive belt, Idler, Tensioner pulley. Brake pads F+R. Suitable coolant, oil top ups. Odd bolts, electrical wiring and a few spades etc. Generic tools, jack, etc.
I'm thinking TD5 Crank sensor... any other odds and sods like that worth carrying?
Post #770470 28th Apr 2019 7:39am
bankz5152
Why brake pads? Seems excessive.
Crank sensor is a good shout and get yourself a Nanocom or Hawkeye Instagram @defender_ventures
Empire Tuning - Agent
Post #770472 28th Apr 2019 8:11am
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Spare fuses and relays. For long trips to remote areas spare fuel pump and fuel filter.
For wading spare engine ECU - this can be preset, so it is possible just swap it, without any need for Nanocom or other diagnostics equipment.
Air filter - for dusty areas ar for very wet weather/wading.
Some fuel hoses and suitable clips for them - original plastic pipes for fuel and cooling water are getting brittle when old.
Most important - RAVE in notebook of smartphone - in PDF files, there are lot of pictures, helpful in remote places garages.
And just don't be afraid and run. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #770480 28th Apr 2019 9:51am
landy andy
A Haynes manual. They are crap, but great for explaining to locals what the problem, or required part is.
Drive belt
Air, oil, and fuel filter.
Prop ujs
Wheel bearing
Also prop bolt tools
Brake pipe crimper
14mm ratchet spanner
Fan spanner’s.
Post #770483 28th Apr 2019 10:06am
mk1collector
Breakdown company card and credit card and your off Thumbs Up Ray
My build thread
Post #770485 28th Apr 2019 10:11am
ibexman
Wheel bearings
Post #770490 28th Apr 2019 10:33am
grafty99
The only sensor that will stop a Td5 running is the crank position sensor. I'd keep one of those handy Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #770527 28th Apr 2019 2:47pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I carry spare belt, fuel pump, a couple of relays, wheel bearings, injector harness because I have a spare, track rod ends, spare rear half shafts when lanning, 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #770600 28th Apr 2019 9:53pm
bankz5152
These lists of spares seem excessive to me. Brake pads and wheel bearings maybe if youre going to the deepest darkest Morocco but not needed for a trip to Wales etc...
We drove to Barcelona last year for the Land Rover Party up through the Pryenees and back down. Only spares I toom where a set of rear shafts, drive flanges, fan belt, Nanocom, fuses, relays and a handfull of other bits. Didnt need any of it. That is until I jumped the 110 up a near vertical bank but that blew the CV. Had I not been a Censored I wouldnt have needed it. That said got a new CV there and repaired it good enough to get around and get back.
We go to Marquenterre each year as well for some pretty hard off roading. Never needed any spares there either (blew a diff once but it was on the way out anyway)
Just look after your landy and give it proper care and attention.
Spare ECU is massively ott as well. The ECUs are quite robust and you wont flood it unless youre sat in 2ft of water for longer than 10 mins. Ive been thru headlight depth in my 110 many times snd never had a drop in the ECU box.
Crank sensor yes. They can ruin your day sharpish.
Great taking a spare fuel pump but are you really going to drop the tank to change it? I certainly wouldnt, but if I where going well outside of the EU id change it before I go. Instagram @defender_ventures
Post #770611 29th Apr 2019 5:54am
gazman
I've done a fuel pump in the depths of Wales. But I've made a easy access hatch in the floor of mine. 2014 - current ..... 2003 defender td5 90 (my car)
Post #770622 29th Apr 2019 7:17am
AMBxx
Am I the only one to carry spare bulbs, or is that too obvious?
Or do I carry spare bulbs because they're one of the few things I'm capable of changing? Embarassed
Post #770623 29th Apr 2019 7:19am
benniferj
Cheers for the replies. Some of the extra bits you've said I do have in the pack anyway - a pair of track rod ends, wheel bearings, generic bits. Pads, well I tend to take as I've had a couple rip off of the backing in the past. Plus they get pretty clogged and have been known to wear quickly in some situations like wet sandy boggy stuff.
My main thing was to ID what things are specific to a TD5 that I'll want to take with me. So really the Crank Sensor, belts, tensioner, idler.
Whoever said a breakdown policy and a credit card - that's cheating eh! I like to drive myself home! Smile
I know most of it is preventative maintenance... Which is what I've been doing for the last couple of months. But we are planning a decent trip through lower France, Pyrenees etc and I don't want to have a problem and wish I had a £20 part sitting in the boot!
Post #770625 29th Apr 2019 7:30am
benniferj
Oooh.. MAF sensor can suddenly go a bit dicky unexpectedly?
Post #770626 29th Apr 2019 7:31am
lightning
You can just disconnect the MAF sensor if you think it’s faulty, and the engine will run fine without it.
Post #770627 29th Apr 2019 7:43am
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Watching this with interest as I’m heading down the bottom of France and northern Italy at the end of June.
Last year I only carried a drive belt and injector harness but I didn’t do any off roaring.
I was planning on taking the same this time but with a spare fuel and air filter. I have thought about the fuel pump but as others said itd be a nightmare job with a full tank of diesel on a track.
Interesting a few of you carry spare half shafts! Are they really that soft?!
Post #770674 29th Apr 2019 12:50pm
