Home > Td5 > Td5 in car spares recommendations? |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
Christ those crank sensors are dear... is a bearmach one ok to carry to get you out of the ?
29th Apr 2019 7:08pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Id go intermotor. Keep an eye on ebay genuine ones can be had for £50 - £100 Instagram @defender_ventures
Empire Tuning - Agent |
29th Apr 2019 8:58pm |
Bought a used genuine on eBay for £7 might try and do a test fit tomorrow to check it works. 👍
11th May 2019 8:15pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 791 |
Depends how remote you plan to go- and who you plan to go with!
one thing not mentioned so far.....spare tophose- the TD5 ones are S**te and the plastic threaded insert has a habit of coming out. For a big trip to Romania whee we knew that spares provision was poor with 2 superficially similar TD5 defenders we had between us F&R shock Wheel bearings Prop UJs Drive flange (pair) CV Pair of half shafts Various Bulbs/fuses/relays/wire Top hose and a selection of oddments of other sized hose Crank sensor Inner tubes Puncture repair kit Various hose clips/nuts/bolts Couple of bits of aluminum sheet Injector seals. Selection of bushes. In the three and a bit weeks and many, many thousands of miles between the 2 cars we had an air con compressor failure, a wheel bearing required tweaking, a snapped rear shock, a minor electrical issue with headlights, a weepy brake caliper- then sadly a Head Gasket failure put an end to our trip. This was on 2 well maintained, regularly serviced vehicles. Chris |
12th May 2019 6:47pm |
