- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
nitram17
You need to use an open ended spanner(8 or 10 mm ?) to get to the top nut on the tip of the alarm (do it by feel)you may just get away with loosening them and pull the alarm towards you(or take nuts off and open out the wings of the bracketand it should fall out) and it should come/slide out of the housing and then you can get to the one nut /bolt holding the bracket..im not sure but you might be able to see the nut from the inside of the engine bay next to the air conditionoing dryer (if you have one )looks like a starter coil but has pipes..sorry but its easier to show than describe.
20th Apr 2019 7:27pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
