Home > Maintenance & Modifications > BBUS Redirection
AMBxx
BBUS Redirection
Spending the weekend doing some security upgrades. All went well until I came to fit the BBUS redirection loom.
I've a late Puma 110 SW. I've found the BBUS behind the left headlight, but can't undo the bolts. It's right high up to the left of the space. I can see two bolts, on the top, but can only just reach one and can't get close to the other.
Short of removing the top of the wing, I can't see how to remove the BBUS.
What am I doing wrong?
Post #769371 20th Apr 2019 5:16pm
nitram17
You need to use an open ended spanner(8 or 10 mm ?) to get to the top nut on the tip of the alarm (do it by feel)you may just get away with loosening them and pull the alarm towards you(or take nuts off and open out the wings of the bracketand it should fall out) and it should come/slide out of the housing and then you can get to the one nut /bolt holding the bracket..im not sure but you might be able to see the nut from the inside of the engine bay next to the air conditionoing dryer (if you have one )looks like a starter coil but has pipes..sorry but its easier to show than describe.
Post #769389 20th Apr 2019 7:27pm
AMBxx
I managed to get the bottom nut off, but was a worried about opening the bracket wider and also of loosening a bolt that I couldn't then reach to tighten.
I'll take another look tomorrow.
Thanks for the help.
Post #769429 21st Apr 2019 5:57am
