![]() | Home > Puma (Tdci) > FORScan OBDII scanner works on PUMA 2.4 TDCI |
4wd-junky Member Since: 31 Aug 2014 Location: UK Posts: 89 ![]() ![]() |
I've just edited the title by adding 2.4, to avoid further disappointment
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
Im fat,grey,58 year old remainer and I follow SAFC..so I am used to dssappointment junky ..I hope you dont think I was wasnt getting at you?......... Caveat emptor is my motto... I was just about to make a obd2 security loom and I wanted something quick and cheap to test the connection and it will do this for me as it establishes a connection ,it just does not recognise the model.
No worries, it's all good.
![]() Anyway, Puma owners will already have had plenty of disappointments, so no point in making it worse for them. ![]() What's an obd2 security loom? |
Its where you remove the wires from the standard obd2 port molex connectorand connect thm to female connector of your choice. Then you make a short loom with the original molex connector at one end and the male version of the new connector at the other end .
Result is there is no standard obd2 port for the thieves to plug into and you have a short loom that allows you to use the standard port for diagnostics servicing ect. Some folk leave the original connector in place with dummy wires (or a positive feed to the connector)so that the thieves spend time trying to get it to work rather than immediatle seeing there is no obd2 port and moving on. |
Ahh ok! ….. sounds like a good job.
XanaX Member Since: 12 Oct 2018 Location: Bordeaux Posts: 13 ![]() ![]() ![]() |
Hi i confirm that. i have bought an elm327 interface and don't work with forscan. My interface work ( i test it) and works with orther software. I will ask on the forum. too bad, this soft seems great ! |
