Home > Puma (Tdci) > Slickshift on a Puma?
Page 3 of 3 <123
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Thanks Dave that explains a lot I was not aware that shift R was relatively new on the market.
I notice after shift R there is a V2 maybe it has a revised design? 2016 Defender Landmark 90
2005 Defender CSW TD5 90XS
Post #760543 24th Feb 2019 11:51am
sven
Norway 2009 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
legin wrote:
"Why does the slickshift not just come as a one piece rather than the banging the two pieces together and the need for a lock screw?" So it can be fully adjustable to suit you sir and helps our friends across the water who drive on the wrong side of the road Very Happy
The reason why it comes in two pieces is that is designed for lhd and rhd. You´ll notice that in the start of the installation video.
Installing it is easy and I didn´t have to bang the two pieces together 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition
Post #760573 24th Feb 2019 3:46pm
Tegner
United Kingdom 2010 Defender 90 Puma 2.4 HT Zermatt Silver
shift R
Any body had any problems with vibration/ rattling with the Shift R, its not the weights as they have already been glued in place
Post #760685 25th Feb 2019 12:32pm
Welshsurferdude
Wales
done 50k miles on a Syncro slick shift so far, works perfect Mr. Green 2008 Santorini Black 110 XS USW (Sold)
2015 Discovery 4.5 Black pack Firenze red XS
2008 Corris Grey 110 XS USW (sold)
2011 Santorini Black 110 XS USW (Sold)
Post #760737 25th Feb 2019 7:08pm
fatboyron
Bit the bullet and ordered a shift r version 2.
Definitely a worthwhile upgrade can feel a massive difference. There's no wobble on the gear stick and don't need to use tape or anything.
Post #761096 27th Feb 2019 9:12pm
nitram17
Dave-H wrote:
Likewise, I prefer the Shift-R version ... Easier to fit and no need to 'tinker' with excess grease or gluing bits to prevent rattles [or bits coming loose!]
Driven vehicles with both versions ... both do exactly the same job Thumbs Up
How much grease did you put in the housing?The instructions are a little vague and i dont want to over grease!
Post #766557 2nd Apr 2019 4:11pm
sven
A lot .. 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition
Post #766561 2nd Apr 2019 4:28pm
Roy5695
All of it! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #766562 2nd Apr 2019 4:35pm
nitram17
Rre you talking shift r ?did you just fill up the housing with grease?
Post #766565 2nd Apr 2019 4:38pm
fatboyron
When I fitted mine I only put a little bit in and wiped it round, that's what it said on the instructions and I used the new plastic bit on the bottom not the old land rover one. I greased that up as well.
Post #766566 2nd Apr 2019 4:41pm
nitram17
Just had chat with tmd online they said fill the housing where the rod end fits into the gearbox and that it!
Post #766569 2nd Apr 2019 4:52pm
nitram17
I havent took it apart yet but what did you mean by : I used the new plastic bit on the bottom not the old land rover one.
All that came in the box is the shift r!Do you mean the black plastic castlated cup that covers the lower ball or am i missing something?
Post #766571 2nd Apr 2019 5:01pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Have you watched the You Tube fitting video? I fitted mine whilst watching that and it’s straightforward.
Post #766572 2nd Apr 2019 5:13pm
nitram17
Thanks BOT very short video but looks like they have used minimal grease and the hardest thing about fixing the shift r will be removing the carpets!
Post #766579 2nd Apr 2019 6:23pm
fatboyron
That's the one, just unclipped it put a bit of grease on clipped back on then greased the top of gear box where it sits in. Then I greased around where the selector is a little bit nothing major and that was it.
Only lift the carpet from the passenger side, and unclipped the gear lever and swapped it over. Bit fiddly but saved taking it all out.
Post #766581 2nd Apr 2019 6:58pm
Page 3 of 3 <123
