![]() | Home > Puma (Tdci) > Slickshift on a Puma? |
sven Member Since: 29 Dec 2011 Location: Oslo Posts: 80 ![]() ![]() ![]() |
The reason why it comes in two pieces is that is designed for lhd and rhd. You´ll notice that in the start of the installation video. Installing it is easy and I didn´t have to bang the two pieces together 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 198 ![]() ![]() ![]() |
Any body had any problems with vibration/ rattling with the Shift R, its not the weights as they have already been glued in place
Welshsurferdude Member Since: 23 Feb 2012 Location: Newport Posts: 2450 ![]() ![]() |
done 50k miles on a Syncro slick shift so far, works perfect
![]() 2015 Discovery 4.5 Black pack Firenze red XS |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 ![]() ![]() |
Bit the bullet and ordered a shift r version 2.
Definitely a worthwhile upgrade can feel a massive difference. There's no wobble on the gear stick and don't need to use tape or anything. |
nitram17 Member Since: 09 Jun 2014 Location: newcastle Posts: 2261 ![]() |
How much grease did you put in the housing?The instructions are a little vague and i dont want to over grease! |
A lot .. 2009 Land Rover Defender 90 SVX Soft top 60th Anniversary Edition
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
All of it! 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html Instagram - @r22oyp Roy |
Rre you talking shift r ?did you just fill up the housing with grease?
When I fitted mine I only put a little bit in and wiped it round, that's what it said on the instructions and I used the new plastic bit on the bottom not the old land rover one. I greased that up as well.
Just had chat with tmd online they said fill the housing where the rod end fits into the gearbox and that it!
I havent took it apart yet but what did you mean by : I used the new plastic bit on the bottom not the old land rover one. All that came in the box is the shift r!Do you mean the black plastic castlated cup that covers the lower ball or am i missing something? |
boxoftricks Member Since: 06 Feb 2019 Location: Home Counties Posts: 748 ![]() ![]() ![]() |
Have you watched the You Tube fitting video? I fitted mine whilst watching that and it’s straightforward. |
Thanks BOT very short video but looks like they have used minimal grease and the hardest thing about fixing the shift r will be removing the carpets!
That's the one, just unclipped it put a bit of grease on clipped back on then greased the top of gear box where it sits in. Then I greased around where the selector is a little bit nothing major and that was it. Only lift the carpet from the passenger side, and unclipped the gear lever and swapped it over. Bit fiddly but saved taking it all out. |
