Home > My Defender > A second 110 on the drive - 300tdi csw BMW powered!
Page 10 of 14 <123 ... 91011 121314>
lb73
Wales
Yes, hopefully will make a start this weekend as the parts from yrm turned up yesterday. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2002 Dax Rush 3.9 V8
2012 Audi A3 tdi
2020 Renault Kangoo electric
Post #755116 30th Jan 2019 9:34pm
L110CDL
Thumbs Up Clayton.
Keeper.
Post #755334 31st Jan 2019 8:24pm
lb73
Wales
Well, there was a bit morerust/rot than I first thought hence it took a bit more time. However the results are’nt too bad, I replaced the hinge bolts as well when I put the door back on. Also fitted a puma door look as well so I can fit the central locking actuator that’s been in thegarage since I did the other doors. I was going to fit a one piece skin, but thought the four piece one might be easier to handle when fitting it to the door frame, plus the orginal skin was four piece.
Just got to sort the wiring out, fit door panel, fit swing wheel carrier along with the paint and glass! 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #760564 24th Feb 2019 2:27pm
L110CDL
That looks to good to paint Wink but it would look better the same colour, good job done there Thumbs Up Clayton.
Keeper.
Post #760781 25th Feb 2019 10:05pm
lb73
Wales
Thanks Clayton , I like it in bare ali as well ! 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #760795 25th Feb 2019 10:51pm
lb73
Wales
Ok, so I finally got round to having the door painted, I did think about having the complete back end painted so the door matched in better, however it the end the wallet ruled. However the match isn’t too bad considering the orginal paint is 20 odd years old
I also fitted a Mantec spare wheel holder, which was a pleasure to fit with all holes lining up first time!
When rebuilding the door back up I bonding the rear glass in place, as previously there was no sealant and it was letting water in hence the rot. I also kept spending and also fitted a mud rear interior panel as it had a diy chequer plate one previously and with fitting a actuator for the central locking I needed the clearance. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #766150 30th Mar 2019 9:13pm
Procta
My rear door had practically split in two! if we had decided to re skin the door like this, it would have dropped to pieces, the frame was well bent in some places. I was looking at putting a later door on, some point this year or maybe next year. But with it been bbqd that plan went out of the window sadly.
colour match looks good mind, if it was red, I recon it would have been a pain in the arse Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #766391 1st Apr 2019 4:09pm
donmacn
Like the new door!
Procta beat me to it by saying that the frame on his rear door was completely knackered - mine too. There was just no way it would have handled the dismantling process without falling apart completely. I once had a tourist come up to me and ask if I was washing the car in salt water! Which is effectively what we do up here for 4 months of the year with all the salt on the roads.
I was also going to comment too that the colour match was good, but that in red it would have been worse.... and then Procta beat me to that as well.
My 100, in Portofino red is so faded and dry looking that any new paint stands out like a sore thumb. So, while my wallet would definitely be happier if I weren't doing this, I'm having to get the car resprayed completely. Though that's after 5 new doors rather than just the tailgate. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #766393 1st Apr 2019 4:19pm
Procta
Me and my mate tried a few times to strengthen the frame again, it was well bent, I think the weight of the spare wheel had practically killed the frame. We tried to bent the full works back into shape but it was game over. Laugh was when the car was BBQed the rear door frame survived and is still there at the finial resting place. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #766406 1st Apr 2019 5:03pm
L110CDL
Great finish to the rear door Thumbs Up
Although i like the aluminium finish, i do like the painted look better Wink Clayton.
Keeper.
Post #766730 3rd Apr 2019 8:11pm
lb73
Wales
Thanks for the comments all. Glad the door is done as is was more work than I thought and more money. Next job repaint the front bumper again! 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #767731 8th Apr 2019 8:27pm
lb73
Wales
It’s been a while since I updated, haven’t had the call to do any major work the last 12months. Just redone the rust protection on the chassis using dintrol. This time I removed the springs and shocks also to make it a bit easier, plus the power coating was peeling on the coil springs so I sorted that at the same time.
Also noticed the rust was weeping through on the front shock absorber turrets - they weren’t the best when I initially bought it , so I ordered a set of the Gwynn Lewis galvanised ones and stuck them on when I rust treated the front.
Just got the rust to sort on the front bumper - still, so I ma6 go for one of the galvanised versions and paint is black. Also mulling over a change of wheels, quite like the banded version of the rostyles, or maybe vbs nemesis? 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #828915 2nd May 2020 4:32pm
L110CDL
Nice bit of work carried out there and thanks for the update and good to see you still have the 110 Thumbs Up Clayton.
Keeper.
Post #829107 3rd May 2020 8:30pm
lb73
Wales
Cheers Clayton, still got it - not a 100% sure if to hang on to it, though I do like working on it. 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200
2012 Audi A3 tdi
Post #829573 6th May 2020 8:57pm
L110CDL
I would love to change your way of thinking about keeping it 100% but only you can make that decision Wink
Yes they are great to work on and the sense of achievement when it's all back together and then you can say " i did that " Very Happy Clayton.
Keeper.
Post #829776 7th May 2020 8:37pm
