Home > Puma (Tdci) > Broken down in France again and now UK.....VERY not happy...
Page 4 of 6 <123456>
Martin
Site Admin
The coil is used by the 10AS to tell the keyfob to send the de-immobilise code back to the 10AS.
You can run without a coil, but you have to press the "unlock" button on the fob just before you start.
Do you have any illumination of the red alarm LED (under the rev counter) in the instrument pack when you have these non start problems?
4 turns then stop means the 10AS has allowed a start but the engine ECU doesn't (no fuel).
No attempt to start with the key turned means the 10AS hasn't allowed a start (hasn't received de-immobilise code from fob).
Some other things to try (fuses etc) here: https://www.defender2.net/forum/topic64972.html  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #765925 29th Mar 2019 11:51am
johnnyd
Hi all
I have had passive immobilse disabled since this happened last year first time, the red light illuminates as normal on arm and extinguishes as normal on disarm
Going to it this afternoon on return home, it now starts, but before then I saw these errors in the nanocom
But after it started they cleared, and the persistant one still there is the one labelled fault 4 of 4, invalid data received......
If the 4 times turnover is indicative of a working immobiliser, are we looking at a fuel issue, or could the ECU just be trashed/unreliable?
JD 2008 TDCi 2.4 XS CSW
Post #765933 29th Mar 2019 12:55pm
Martin
Site Admin
Check the engine ECU loom for damage/fraying/water - perhaps remove the ECU and check in the sockets too.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #765935 29th Mar 2019 12:58pm
dorsetsmith
Post #765937 29th Mar 2019 1:05pm
johnnyd
Dorsetsmith, do you per chance have Service Message 44410, my temperature gauge does not go into the red
Post #765943 29th Mar 2019 1:38pm
johnnyd
Hi Martin
I assume this is the ECU with 3 looms going into it ?
Post #765944 29th Mar 2019 1:42pm
Martin
Site Admin
Yep on the bulkhead tucked down behind the engine.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #765945 29th Mar 2019 1:58pm
dorsetsmith
JD
No i don't
Post #765963 29th Mar 2019 3:03pm
johnnyd
Hmmm that service bulletin says if the PCM is earlier that 2009 then replace it, given mine is 2008 I would say its earlier lol
Where/what is the PCM?
Post #765964 29th Mar 2019 3:09pm
Martin
Site Admin
dorsetsmith wrote:
JD
No i don't
Can't find SSM 44410 on Topix either.
PCM = Engine ECU  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #765980 29th Mar 2019 4:53pm
johnnyd
Could someone do me a favour, can anyone with a 2.4 confirm which relay numbers go in the yellow spaces here, a guy at the garage swapped 2 out to rule out the starter motor relay and I would like to put them back where they were now as its not that.
I have two relays ++07513 and ++08011
Thanks
Post #766047 30th Mar 2019 10:04am
johnnyd
Well Martin now has my defender.......I have exhausted my skills and analysis, so he is going to have a look next week with more equipment and knowledge than me to see whats going on.......hopefully...... Bow down
Post #766115 30th Mar 2019 5:58pm
familymad
Good result 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #766184 31st Mar 2019 6:22am
diduan
Bulgaria
My 2.4 was a non-starter once, but after pulling out the main relais it was fine for a while. As the non-starting issue always came back, sooner or later, i was convinced this was not a relais issue. Then one day I twisted a bit the feet of the relais with pliers, no starting issues since. Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt
Post #766217 31st Mar 2019 10:18am
Martin
Site Admin
johnnyd now has his 90 back, and a smile on his face compared to the grimace last Saturday Laughing
After logging voltages going to the ECU and wiring up a temporary manual starter button the issue was traced to a failed ignition switch which was cutting the ignition power shortly after the key was turned to start.
The ECU received power for just long enough to allow a few turns of the engine before it powered down and stopped fuelling and cut the starter relay. Or the engine would 'catch' before this, but the ECU power-down caused a 'cough' in fuelling but the engine would have enough momentum to keep running when it powered back up (just like turning the ignition off and on again quickly when running).
Upon removal it also turns out the switch had also been wired up incorrectly when replaced as part of a key barrel/column lock change in the past. This was causing an odd power-down problem when the fan was running and the ignition switched off.
Following a new switch and the terminals returning to the right places johnnyd now has the "AUX" position for the radio and heater fans restored as well Thumbs Up
Few other bits and bobs found and sorted at the same time and he went away a happy chappy Mr. Green  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #767041 5th Apr 2019 3:49pm
