Home > Wheels & Tyres > What Size Tyres
chalky
What Size Tyres
i,m going to put some BFG all terains on my 90 CSW its an 08 plate
What size ?
i had a T plate 300 TDI that had some very good sized BFG's on it. If i remember correctly most of the Later 300 TDI DEFENDERS came with these on ! what size were they ?
i dont want to go stupid on size, or have to modify the steering arms i just wamt to fit and forget.
Thanks DEFENDER XS CSW 08 TONGA GREEN
Post #7618 21st Feb 2009 11:24pm
kljw
Scotland 2009 Defender 90 Puma 2.4 SVX Soft Top Auto Santorini Black
hi
i am looking at black sport 18" rims, with mickey thompson 305x60x18 AT tyres. i think it will look great.
will post some pictures ina few weeks, once all is done so to speak. Cheers
keith
puer claudius
Post #7622 22nd Feb 2009 9:18am
Pob
United Kingdom 2008 Defender 110 Puma 2.4 HT Rimini Red
What is the biggest size you can go without fouling steering or anything? I was thinking about 255/85 16 on my 110
So to clarify the 255 is the width across the tyre in mm, the 85 is the percentage of height of the wheel/tyre diametre and the 16 means 16" wheel ?
Post #7624 22nd Feb 2009 9:41am
Glynparry25
There is a good chance you will have to adjust the bump stops. Other option is the 265/75/16 for a bit more width- are you looking at different wheels? or wheel spacers?
Spot on.
Glyn
Post #7625 22nd Feb 2009 12:13pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Running 275 / 70 / 16's on the Puma.. adjusted steering for lock, with 30mm spacers, just rubs the front radius arms.. hope that helps! 110 Tdci Double Cab
Post #7626 22nd Feb 2009 1:24pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
My brothers defender 50th has 265 /75/16 BFG all terrains on it as fitted as standard at the time.
Mine has 235/85/16 BFG all terrains.
Daz110
Post #7629 22nd Feb 2009 2:30pm
chalky
Thanks Daz,
I believe mine were the same as the 50th in height & width
So am I right in thinking that ur tyres are not as wide as those on ur brothers vehicle ? DEFENDER XS CSW 08 TONGA GREEN
Post #7630 22nd Feb 2009 3:14pm
AndrewS
Got 285's on mine no problem Thumbs Up
Post #7633 22nd Feb 2009 5:00pm
Pob
Thanks, interesting - not wanting to hi-jack the original thread Embarassed
So what is the biggest (tallest) tyre on 16" wheels can be fitted? is it 285/65 ? Without issues with stuff rubbing and fouling or is it best to stick with the 265/75 16 option.
I was thinking of boost copies with BFG All terrain or Cooper STT tyres.
Post #7634 22nd Feb 2009 5:40pm
RickA
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Tyres
Hi,
I run 265/75-16 STT's on standard 'Boost' alloys with 30mm spacers fitted. No problem with clearance and look great!
Hope that helps!
Cheers, Rick
Post #7639 22nd Feb 2009 8:32pm
DAZ110
Hi chalky,
Yes mine are 30mm less wide.
265-235=30
I'm good at maths you know!
Daz110
Post #7640 22nd Feb 2009 8:37pm
DAZ110
....and I have 30mm wheel spacers to help increase the steering lock on my 110.
Daz110
Post #7641 22nd Feb 2009 8:41pm
chalky
Thanks Daz,
Can i fit without spacers then or will i need these ?
Pretty sure my other 90 didnt have them but it probably had the stops altered when fitted at the factory ?
I have a pic of my old truck with said tyres im just a bit computer thick and cant up load it but if any body can do it for me i can mail u one ? DEFENDER XS CSW 08 TONGA GREEN
Post #7645 23rd Feb 2009 12:56am
110SEB
Purely aesthetically, I think MTs look much better a bit fatter than standard sized Defender rubber. For me 265s are perfect.
I do think though that ATs look just right with 235/85.
The real question is, however, white letters showing or hidden?
Post #7649 23rd Feb 2009 10:11am
chalky
Definately inside out and hidden ! DEFENDER XS CSW 08 TONGA GREEN
Post #7650 23rd Feb 2009 10:23am
