![]() | Home > Wheels & Tyres > What Size Tyres |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
Genis Member Since: 25 Jan 2009 Location: Windhoek Posts: 17 ![]() ![]() ![]() |
255/85 R 16's fit without any rubbing so far. That's on a 90. Tested it on a few cross-axles without any load in the back and it cleared, but it's tight.
Andrew388 Member Since: 25 Feb 2009 Location: Westen Cape Posts: 9 ![]() ![]() |
As I understand it, the biggest size one can go without modification is 265 75 16.
Genis: where did you get that size tyre? I have been looking, but no one sells them in SA that I know of. AndrewS: is your suspension standard on the 285's? I have a 90 with 2 inch lift and disconnected anti-sway bars, and am hesitant to fit 285's for fear of them rubbing on articulation. My truck has an RTI of 761 already, and I still need to fit the longer shocks, so there is a high possibility that the tyres will rub on full articulation with 285's. |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
85 is 85% of the tread width. So the wall on say a 285 wide tyre is 85% of the width which is 242.25mm high ![]() |
