![]() | Home > Maintenance & Modifications > LOF POWERspring pedal assist |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3354 ![]() ![]() ![]() |
https://lofclutches.com/shop/td5/l-o-f-pow...cba1185463
Could be good for those of us with dicky knees. https://www.instagram.com/lof_clutches/ |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
It seems such a simple idea (compared to the red rooster) if it works, surprised it hasn't been done before. James
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
Along with one of there clutch kits and flywheel etc, I'm having a spring fitted also next week, I'll report back
Think I may have to try one. Rude not to at that price.
I couldn't be happier with the LOF clutch. It's brilliant. |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Be interested to find out how the clutches perform
Look forward to hearing the results Daisy90, thank you. James
It would have cost Landrover under £100 extra to have a galvanized chassis, - they didn't do that either 😕 |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2205 ![]() ![]() ![]() |
It has.its been around for at least 7 years. Just made my britpart i had one in my 90 and have one in my 110. Probably arnt identcal but do the exaft same job. |
I’ve ordered one. Knowing Luke’s work I reckon it’s bound to be decent but if not then it’s only £25 spent and 10 minutes to put back to standard.
No brainer. |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1881 ![]() ![]() |
Which of the clutches did you go for, Zed? I see they're offering 3. I feel my use/circumstances would point to the middle one, but just curious. Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
Only down side I could think of is in the long term the spring gets weak but could take years for this to happen.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5852 ![]() ![]() |
I’ve just ordered one of the springs.
A couple of months ago I fitted the same style of spring to replace my standard long spring, and it made the pedal a lot better, but it now squeaks on operating. So I’ve ordered the new one fro LOF and will see it it’s any better than the previous I fitted which I was disappointed with the fact it was Britpart when the box arrived. Andy. |
I went for the extreme spec. Middle of the 3 LOF clutches available for Puma. No rattles, clunks or slipping even when towing or acting like bit of a hooligan. TBH standard would have been more than OK for my use but the price difference wasn’t huge so I went for it. |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2719 ![]() ![]() |
I think they're claiming a further reduction of effort compared even to the genuine 'over-centre' spring. |
