![]() | Home > Maintenance & Modifications > Best DAB Ariel? |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
Recently upgraded my standard stereo for a double din and added a DAB splitter to the existing Ariel.
This was rubbish. Then I added a window mount one. Much better, but still not as good as any normal car andbstruggles to get FM or Dab in some areas. What brand and model of Ariel do people use that actually works! ![]() Click image to enlarge |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
I can't really help but all I would add as a recent convert to DAB (in my company eurobox) is I've been suprised how bad the digital signal is over large swathes of the countryside.
Also forum sponsor Brendan had an offer on recently on the Nakawhatsitcalled aerial https://www.defender2.net/forum/topic65245.html?highlight=dab James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
I just added a powered splitter to the factory OEM aerial when I fitted my Pure Highway DAB radio, works a treat, no complaints at all
![]() Edited to add - This one - https://www.dynamicsounds.co.uk/autoleads-...itter.html |
Tilly Member Since: 04 May 2016 Location: Grimsby Posts: 37 ![]() ![]() ![]() |
Same here using a powered splitter. Never had any signal loss using the standard aerial.
I must live in a rubbish signal area as the town centre is fine, but near my house is just awful.
Only concern is all other cars work great. Mine canβt get anything but static on dab and FM. Anyone used the nakatanakaka..... one? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20759 ![]() ![]() |
It can vary a lot purely on signal where you are rather than the aerial equipment you have but both have a bearing on each other of course.
I found on mine with the original aerial even FM was rubbish never mind DAB. I have the Naka Aerial kit, but won't be fitting it for quite a long time yet and don't have a DAB capable HU just yet either. Plenty have bought them and fitted here so shouldn't be long before someone is along. ![]() β½οΈπ’οΈβοΈπ§°πͺ |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 ![]() ![]() ![]() |
I have a nakajobby one being fitted on the wing next week, I currently use an external halfrauds one, so can compare once it comes back
Look forward to it.
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
I would just like FM radio mine's all over the place some days good other no reception is it the radio or the aerial both standard Land Rover
You could fit a booster, the Naka Aerial allows you to use just FM or DAB or both combined.
On factory HU you can use DIN FM with the Naka Aerial no problem. Just Earth and power it from another source and it'll boost it, the factory Aerial is not boosted. Most vehicles these days are as boosted as standard. You can even boost the factory Aerial if you wanted. WeWillWinπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
Thanks Steve I will see about a getting a booster fitted.
Spoke to auto engineer and they reckon the fault with mine may be a dodgy USB charger in the place of the cigarette lighter.
This is a blue sea one so iβm Doubtful... Will see but for now not going to spend Β£80 on another antenna. Hmmm... |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2326 ![]() ![]() ![]() |
I have a blue sea usb, when used it certainly interferes with fm reception. I was pointed in this direction by fellow forum members when I queried the performance of the older type nakatanenga aerial.
I don't know about DAB as I don't have it, I'm afraid. Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Mine causes interference (maybe) when not in use. Just simply by being there.
Will see later when I get the dash off and remove it. |
