Home > Maintenance & Modifications > Best DAB Ariel? |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 874 |
Do you have a pic of it fitted as this may be just the job.
Cheers |
8th Mar 2019 9:27pm |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 186 |
I've had one of these fitted for over a year great signal even in remote areas beats my Audi hands down. this one has GPS as my unit has sat nav but they done with just FM/DAB it needs a 12v supply
http://www.connects2.co.uk/Product/ProductItem/CT27UV56 without GPS http://www.connects2.co.uk/Product/ProductItem/CT27UV53 |
10th Mar 2019 2:21pm |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 |
I also get interference when I put the lights on spoke to a ICE man in Harlow on Saturday he told me he's done loads of Defenders and fits a VW aerial and that works so booked in to have this fitted next week, fingers crossed this will work.
10th Mar 2019 3:20pm |
Emptywallet Member Since: 03 Mar 2018 Location: Alresford Posts: 31 |
Here you go.
10th Mar 2019 5:22pm |
Click image to enlarge Here you go. Click image to enlarge Click image to enlarge |
10th Mar 2019 5:31pm |
OK Problem solved.
The DAB tuner on certain kenwood and JVC models has an inherant fault in them. Swapped to a poineer in the workshop and worked fine. Will put a post in about the models affected but itæs the ones that are half defth (Not standard depth) The models affected are the JVC KW-M745DBT sold on Mudstuff and the Kenwood DMX7018 The full depth models such as the kenwood DMX7017 are ok. I've also tested 4 types of car airiel before swapping the head unit and the best one by far for reception is the opriginal vehicle one. Go figure. he is no interference from the bluesea USB. Have an official reply from Kenwood to clarify. Next batch of units will be redesigned and will be available in June/July |
22nd Mar 2019 11:27am |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 |
I have the Naka antenna, and a splitter box so it picks up DAB and FM. It's very good (though if I use one of my 4 usb sockets on the dash, the DAB is lost and the FM turns to mush but i'm sure that's a wiring problem not a Naka problem (just can't find the solution yet!) 110 Defender 300tdi & Penman trailer with ally exped top and roof tent |
23rd Apr 2019 3:08pm |
