Home > Puma (Tdci) > Seat wiring spec |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6605 |
No relay, directly switched by the dash switches. 1988 90 Td5 NAS soft top
2015 D90 XS SW |
4th Mar 2019 8:43pm |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Just to add to Martins comment above, the Td5 seat heater circuit is fed from a single 20A fuse. (Same seat heaters.)
5th Mar 2019 7:58am |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 208 |
Thanks
5th Mar 2019 8:36am |
Same with the Puma, there's a common 20A fuse supplying both switches.
However take care adding new loads as there is a "weak" link in the ground path, there is only a single 0.5mm² cable acting as the ground for both seats (see below). Click image to enlarge 1988 90 Td5 NAS soft top 2015 D90 XS SW |
5th Mar 2019 9:05am |
Earth side "smoky fuse" - nice touch
5th Mar 2019 9:24am |
