![]() | Home > Puma (Tdci) > Seat wiring spec |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
No relay, directly switched by the dash switches.
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 ![]() ![]() ![]() |
Just to add to Martins comment above, the Td5 seat heater circuit is fed from a single 20A fuse. (Same seat heaters.)
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
Thanks
Same with the Puma, there's a common 20A fuse supplying both switches.
However take care adding new loads as there is a "weak" link in the ground path, there is only a single 0.5mm² cable acting as the ground for both seats (see below). ![]() Click image to enlarge ![]() ![]() |
Earth side "smoky fuse" - nice touch
