Page 110 of 1377 <123 ... 109110111 ... 137513761377>
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
fekete wrote:
PMonkey mine was like that and K9F put some grease on it and in it not sure what it was called but it fixed it Thumbs Up
Thanks Fekete, but RD is spot on. Many of the the wires had just corroded away and the whole thing was a mess, so I decided it was beyond salvaging. Probably could have stripped it all out and started again but really couldn't be bothered for the sake of the cost of a new one (about £40'ish)... lazy I know.... Sad
New one has been treated with ACF50 Corrosion block grease .... which perhaps is what K9F may have used to bring yours back to life? Jon - 110 td5 [sold]. Currently Defenderless.
Post #75494 12th Jun 2011 12:16pm
110SEB
Party Monkey, where do you mount your trailer socket? If not already there I can recommend in the rear X member recess - it goes a long way to keeping it safe and cr@p free.
Post #75495 12th Jun 2011 12:19pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
PMonkey mine was really rusty inside where you plug the trailer plug in.... when i braked my headlights use to come on ? as said the grease has worked.... when K9F did mine he looked at his and it was the same rusty inside and he never uses it.... now you have greased your's up it should be fine Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #75514 12th Jun 2011 3:12pm
party monkey
Just on a side bracket on the drop plate, which was how I inherited it. Good shout on the cross member recess - will take a look at that Thumbs Up
@fekete.... yep all should be good now Thumbs Up I only came across this recently when testing my new lightboard for the bike rack. Good job it was in these circumstances and not when I did actually need to tow something
Thanks all.... Jon - 110 td5 [sold]. Currently Defenderless.
Post #75515 12th Jun 2011 3:32pm
CR
Ireland 2011 Defender 110 Puma 2.4 CSW Santorini Black
Cleaned Cleaned and Cleaned and then Cleaned some more !
Post #75768 14th Jun 2011 11:22am
Zagato
Very nice CR Thumbs Up
Put a load of bungs in the chassis side holes leaving the bottom ones clear to drain water. Still have to seal the gaping holes Shocked on the front of the dumb irons. Why do they leave them like that Shocked LR's usually have plates welded over to stop all the crud and rain driving into the chassis innards Confused Will also seal the two big holes behind the front wheels which would just act as a funnel straight into the chassis Confused
Used more Dinitrol and also bought some ACF-50 on BigMikes recommendation and have used it in the engine bay on the electrics and rusting common rail, looks to be good stuff, and easy to use especially with the extension nozzle! I have put it also on the badly rusting Series2 rear cross-member for the ultimate test to see how it copes. I was going to buy some of the Dielectric grease but can't be bothered disconnecting everything to treat it all and this ACF-50 along with the Wurth Anti-Corrosion wax I have plastered everything with should do the job. Thumbs Up As others have said it looks to be miracle stuff that can do more than one thing - I need to order another can Embarassed
Can be got through E-bay from Wemoto.com £12.45 delivered (a lot cheaper than the £16 for the Wurth stuff!)
Post #75769 14th Jun 2011 11:22am
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Wow!! Thumbs Up :mrgreen:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Defender 110XS SW gone... now VW California 180 4 Motion.
Post #75773 14th Jun 2011 11:45am
mse
What will you do if it ever rusts.
Word of advice...keep the front dumb irons open DO NOT seal them.
If you really want ill sell you the proper rubber inserts (choose your age) as the first thing I do is remove them - waxoyl and leave open.
The number of defenders that have had them covered - the crap still gets in, the rots it - even if you waxoyl it.
Oh and incidentally the hole is a pillar jack point Thumbs Up Mike
Post #75818 14th Jun 2011 5:00pm
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
Fixed mine Thumbs Up Replaced the clutch master cylinder as it was leaking. Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #75830 14th Jun 2011 5:38pm
BigMike
Went to scotland to pick up some bits for my landcruiser Laughing
lovely drive though, fantastic
Post #75839 14th Jun 2011 5:58pm
Lorryman100
Well it is God's Country Whistle Very Happy
Post #75845 14th Jun 2011 6:40pm
Zagato
"proper rubber inserts" MSE, Thanks for that, good to know they produced them. Saves on more time fabricating things! I have even ordered the Entreq mudflap reinforcement brackets - how lazy is that!
Post #75897 14th Jun 2011 8:50pm
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
Fitted aerial mount for CB on rear left light guard. Also fitted an earth wire. It's been 20 years since I last had a cb, but this time I went for a handheld model, so I can easily transfer it to my 2a (no roof, so no need for external aerial).
Handheld actually worked quite well inside the 90 with the rubber duck fitted, but I came across my old mirror/bike aerial mount, so I thought, what the hell.
Chris. http://shropshirelandrovers.freeforums.org
2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW.
Previous LR's: Michael, my 2008 Defender 90 XS SW.
Machinas oportet intrare non capsicum annuum faveo
Post #75920 14th Jun 2011 11:27pm
DefenderOfTheEarth
Cin - who are you CBing?! Defender 110XS SW gone... now VW California 180 4 Motion.
Post #75955 15th Jun 2011 11:06am
cinstone
Anyone within range I suppose, but really it's just for inter vehicle communication on runs out green laning and such.
Post #75982 15th Jun 2011 1:06pm
