![]() | Home > Puma (Tdci) > low power at low revs hose leak? no fault light (yet) |
nidge n Member Since: 04 Feb 2012 Location: Cheshire Posts: 720 ![]() ![]() |
can't help you on an independent as I'm from up north, however i had exactly the same problem today. Whilst the hose was clearly suffering from a leak the fault light took some considerable time to come on and take me to limp mode. You can't mistake the rushing of air, mine came as low as 1,500 to 2,000 revs. Main dealer pricing is ridicules, I was going to fix the problem myself over the weekend, but my local indi quoted me £170 including part, so lazy boy had them fix it. `Good luck
Natlas Member Since: 20 Mar 2013 Location: West Sussex Posts: 462 ![]() ![]() ![]() |
Which of your hoses was leaking Nidge? I understand there is a choice of about 3 that may fail. 2.2 90 XS
88" Series One Old Norton ![]() Minerva |
The elbow on passenger side, small split. When I first heard the blowing I thought it would be the most common hose located drivers side near the steering link. Good luck
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
If intercooler hose was split it would be underpowered on boost, possible black smoke too depending how much the dpf collects. Cheers
Swine&Small Member Since: 20 Mar 2017 Location: Norfolk Posts: 1223 ![]() ![]() |
At that sort of hourly rate it seems they are trying to recoup some of the losses L/R reported today. These appear to be write downs on bad decisions. Again ![]() 1967 Morris Traveller 1966 Morris Convertible 2012 VW T5 Camper Quod Abundat Non Obstat. |
