Home > Puma (Tdci) > Weepy wheel?
eutek
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Weepy wheel?
I noticed that there seems to be a mild oil leak on my right rear wheel - none of the others have this.
Has anyone else experienced this? Any thoughts as to what it could be?
I clean it up, leave the 110 parked up a few days and it is back...
Post #75628 13th Jun 2011 5:34pm
BigMike
could be one of a few things really. take the wheel of and take a look.
Post #75631 13th Jun 2011 5:56pm
Zagato
You got a dog Whistle
Post #75632 13th Jun 2011 6:10pm
eutek
Ha ha... if only, he'd chase away the neighbour's cat - who is fond of taking dumps in our flowers.
Post #75634 13th Jun 2011 6:14pm
Happyoldgit
Could be anti seize that they put on between the hub and wheel. Is the backplate wet? Steve.
http://forums.lr4x4.com
Post #75645 13th Jun 2011 6:51pm
cinstone
England 2015 Defender 90 Puma 2.2 XS CSW Keswick Green
Stick ya finger on it and smell it. That should narrow things down.
Chris.
Post #75664 13th Jun 2011 7:56pm
Lorryman100
It would be worth checking the brake fluid level as well. If it's not at the full level take off the wheel and check that the brake pipes not cracked/split. Also check the bleed nipple (if it has one, not checked) hasn't been sheared off or is loose. Also check the shock absorber isn't leaking oil. Once the wheel is off dirt will have adhered to the oil so you will be able too see where it is coming from.
Post #75668 13th Jun 2011 8:19pm
BigMike
I'll have 10 p on shock absorber.
Post #75671 13th Jun 2011 8:24pm
mse
I bet the dealer will still say they all do it. Mike
Post #75682 13th Jun 2011 9:19pm
yanto
Wales
would'nt brake fluid burn through the paint??
Post #75708 13th Jun 2011 10:04pm
spudfan
Ireland
Had a leaky break cylinder on a tdi do something similar but on the inside of the wheel. Then again they were drum breaks so I would check the brake fluid level as suggested. Also do you notice any difference in how the vehicle comes to a stop when you apply the breaks? 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #75729 13th Jun 2011 11:15pm
eutek
Thanks for the suggestions, I'll take the wheel off today or tomorrow and have a look!
Post #75734 14th Jun 2011 6:07am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
my bet is, If it isn't the drive flange leaking then it's the inner bearing grease seal Original Member Pie n Pea Club.
110 HCPU Tipper
Post #75736 14th Jun 2011 6:53am
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
I had that on my old TD5, turned out to be a broken hub, the garage where surprised it hadn't seized up and exploded so I suggest you get it looked at ASAP
Post #75761 14th Jun 2011 11:07am
