![]() | Home > Puma (Tdci) > Weepy wheel? |
could be one of a few things really. take the wheel of and take a look.
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 ![]() ![]() |
You got a dog
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Ha ha... if only, he'd chase away the neighbour's cat - who is fond of taking dumps in our flowers. |
Could be anti seize that they put on between the hub and wheel. Is the backplate wet? Steve.
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Stick ya finger on it and smell it. That should narrow things down.
Chris. |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
It would be worth checking the brake fluid level as well. If it's not at the full level take off the wheel and check that the brake pipes not cracked/split. Also check the bleed nipple (if it has one, not checked) hasn't been sheared off or is loose. Also check the shock absorber isn't leaking oil. Once the wheel is off dirt will have adhered to the oil so you will be able too see where it is coming from.
I'll have 10 p on shock absorber.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 ![]() ![]() ![]() |
I bet the dealer will still say they all do it. Mike
yanto Member Since: 03 Sep 2009 Location: caerleon Posts: 230 ![]() ![]() |
would'nt brake fluid burn through the paint??
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4736 ![]() ![]() |
Had a leaky break cylinder on a tdi do something similar but on the inside of the wheel. Then again they were drum breaks so I would check the brake fluid level as suggested. Also do you notice any difference in how the vehicle comes to a stop when you apply the breaks? 1982 88" 2.25 diesel
Thanks for the suggestions, I'll take the wheel off today or tomorrow and have a look!
my bet is, If it isn't the drive flange leaking then it's the inner bearing grease seal Original Member Pie n Pea Club.
110 HCPU Tipper |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
I had that on my old TD5, turned out to be a broken hub, the garage where surprised it hadn't seized up and exploded so I suggest you get it looked at ASAP
