Home > Maintenance & Modifications > Seat riser rails comparison -- too much choice
Best front Sear risers - rails
Nakatanenga basic rails
15%
 15%  [3]
Mud Rails
60%
 60%  [12]
Far Corners Flat bar
0%
 0%  [0]
Defender upgrades
10%
 10%  [2]
Exmore trim risers
0%
 0%  [0]
Far corners box version
5%
 5%  [1]
Nakatanenga Premium
5%
 5%  [1]
Island 4x4 quick release
5%
 5%  [1]
Total Votes: 20
PCM
It seems that the choice of seat rails has continued to go up to the point I'm at a loss as to if there is now any difference.
In terms of choice. a quick look about and there is the following (some may be missed)
The Below is in price order from manufacturers websites today. To be fair and do not include postage calculations.
Basic washers or cut cox bar. Homemade jobby £0
Posh machined aluminium spacers £26
https://www.davidbowyer.co.uk/_main/land_r...r_kits.htm
Nakatanenga basic rails £43
https://www.4x4overlander.com/product/defender-seat-risers/
Mud Rails £49
https://www.mudstuff.co.uk/mud-seat-rails.html
Far corners £49.99
https://farcorners.co.uk/product/far-defender-front-seat-risers/
Defender upgrades £50
http://defenderupgrades.co.uk/product/land...eat-riser/
Exmore trim risers £58.20
https://www.exmoortrim.co.uk/seat-riser.html
Far corners box version £68.88
https://farcorners.co.uk/product/defender-...-per-seat/
Nakatanenga Premium £75
https://www.4x4overlander.com/product/defe...s-premium/
Island 4x4 £132
https://www.island-4x4.co.uk/defender-seat...-7404.html
I'm thinking the exmore, defender updrades and nakatanenga premium ones are all much of a muchness so on price itæd be the defender upgrade ones and save £50.
Mud, Nakatanenga basic, far corners and the island offshore are all the same ish some box, some bent flat bar. (huge price range)
Anyone been in a position to have tried the different types. In a real world comparison.
Have I missed any. I'll update the post and add to the never ending poll
Post #754197 26th Jan 2019 11:30pm
Badger110
United Kingdom 2011 Defender 110 Puma 2.4 USW Buckingham Blue
You missed out a box of penny washers, cheapest by far Thumbs Up
Post #754198 26th Jan 2019 11:45pm
PCM
Cheers Badger Thumbs Up
I wondered what to do about the home made options, I suppose I could probably buy some box section and drill a few holes to make one myself but my welding is c**p and i'd probably buy the wrong washers, Plus the pro ones do look neat.
So for now I'm considering / comparing the 'posh' versions only and admire anyone who has made their own.
Post #754203 27th Jan 2019 12:40am
grafty99
To be honest I think they'll all move the seat to pretty much the same place, as they all have to lift it above the seat box lip with enough clearance for the existing bolts to go in and the new ones in the relocated holes for the seat.
Position/comfort is such a personal thing its a hard one to advise really.
Unless you want something particularly pretty then the cheapest ones will do the job Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #754208 27th Jan 2019 3:05am
lordackers
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Bonatti Grey
This worked a treat for me Razz
Post #754218 27th Jan 2019 8:10am
Bluest
I made my own, similar to the Mud ones, you don’t need to do any welding. All you need is a saw, and step drill, and some box steel. If you want to be really fancy you could paint them and put some plastic blanking plugs in the end. 2007 110 TDCi Station Wagon XS
Post #754222 27th Jan 2019 8:36am
jst
plus https://www.davidbowyer.co.uk/_main/land_r...r_kits.htm @ £26 Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #754223 27th Jan 2019 8:38am
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
I'd suggest giving the penny washers - or something similar - a try before anything else.
All of the seat risers raise the rear of the seat to clear the lip at the rear of the seatbox to a greater or lesser degree, but all of them will raise it by a lot more more than what you can achieve with a few washers. For example on my 110 the sliding part of the seat rail clears the lip by around a millimetre.
The issue then is that the extra height may not be ideal - for example being able to see out of the side window easily, which is what I found uncomfortable at T junctions, cross roads etc.
Give the washers a go. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #754224 27th Jan 2019 8:42am
jst
plus most commercial options change the seat base angle too, which isint always ideal. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #754234 27th Jan 2019 9:05am
discomog
It's sometimes an advantage to change the seat angle. I needed to raise the rear, which meant lowering the front as the front of the original seat base was affecting an old knee injury. Nakatanenga seat riser has been more effective than NHS physios! Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #754237 27th Jan 2019 9:09am
landy andy
I’ve recently bought two sets from 4x4 overlander that raised the rear but not the front. (Rear by 50mm front 10mm or similar).
I wouldn’t buy them again for two reasons.
Not raising the front makes the seat base the wrong angle so on the drivers side I’ve ended up using packers, but at least you can tune it to your preference
One raiser of the pair, on both seats hit the a bolt that is part of the construction of the seat box. Nothing major but a pain. As bolt needs removal and can’t be replaced. This would be the same on any flat bar makes, only resolved by using box style.
I don’t remember any issues with mud rails that I’ve previously purchased.
Post #754239 27th Jan 2019 9:14am
PCM
Cheers nosnibod
You're totally right, I'll give the washers a go to check teh heights then buy the one that best fits.
I don't like the seat at the moment as my legs don't actually touch any of it and just arch up. Just my A**e touches.
I tried to update the poll with washers, but can't figure it out. Sorry..
Post #754242 27th Jan 2019 9:19am
dotom
Germany 2016 Defender 90 Puma 2.2 XS CSW Corris Grey
Good morning everybody. Just to complete the list, i have these
https://shop.ex-tec.de/de/innenausbau-inte...erung.html
and like the look and seating position very much.
Regards
Tom
Post #754253 27th Jan 2019 10:30am
NormanD
England 2015 Defender 110 Puma 2.2 USW Santorini Black
I'm using set of the Island 4X4 seat risers ( https://www.island-4x4.co.uk/defender-seat...-7404.html ), originally bought from Exmoor Trim a long time ago, These allow the seat angle to be adjusted either way for angle, excellent bits of kit, would buy another pair, but would be looking for a discount. NormanD WE191
2015 110 XS Utility
2014 VW Caravelle 180 Executive
Post #754263 27th Jan 2019 11:07am
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
I made my own too ...... a length of 2” channel (easier than box section ) and 8 longer (75mm) bolts 😎
Coat of black paint and sorted ..... Total cost about a tenner 👍🏻 Guns and Landrovers .... anything else is irrelevant.
Post #754277 27th Jan 2019 11:43am
