Home > Puma (Tdci) > Nanocom - upgrade or replace |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 623 |
Upgrade - OBDII dongles are good for reading some fault codes, but Nanocom is much better to accessing all parts of ECUs, not only reading fault codes. Funkctions like setting parameters of alarm, bleeding ABS, checking ECU outputs, ... are possible with Nanocom, but normally not with OBDII dongles. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
24th Jan 2019 9:31am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
Definitely upgrade, I bought my Nanocom when I had a D3, then added the Td5 code for my Defender, (also works on D2,) and then added Freelander 2 when I got one.
As MadTom says, a Nanocom will do so much more than a generic reader which generally only reads standard engine ECU data. Nanocom is designed to access all modules of the car in question, many of which are very to specific to the model. |
24th Jan 2019 11:20am |
stevec205gti Member Since: 31 Jul 2018 Location: Nr Cambridge Posts: 24 |
It´s the FORScan thread that´s got me questioning things - it seems to offer a few things the Nanocom can´t but these are engine based, so I guess I´m just trying to get a better handle on what the Nanocom is bringing to the party that is needed by me.
24th Jan 2019 11:28am |
I need to buy another 2 unlock codes only one is needed NCOM14
24th Jan 2019 11:29am |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
The only thing ForScan won't do is the 10AS alarm/immobiliser unit.
This could be a big deal to you if you want to program keys etc. For the sake of £10 you could buy the correct adapter on eBay and try ForScan for yourself 👍🏼 Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
25th Jan 2019 6:32am |
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 484 |
Why will you take a decision for only one of them if you can have both of them ?
26th Jan 2019 3:13pm |
Because in theory I could sell it, use the money to get a double DIN android head unit, then get forscan for Android and put in on the head unit.
28th Jan 2019 8:43am |
