Home > My Defender > What Did You Do In Your Defender Today |
Keith5 Member Since: 27 May 2016 Location: Scotland Posts: 356 |
USB outlet looks very neat.
Where did you connect it in? Keith |
20th Jan 2019 11:28am |
Nigelpugh7 Member Since: 18 May 2018 Location: Solihull Posts: 115 |
Had 6 hours of off roading for customers this week, so it was time to put the new extreme suspension through its paces.
Click image to enlarge Click image to enlarge Click image to enlarge Pleased to report it works a great! The hydraulic bump stops in particular are great at stopping extreme body roll! |
20th Jan 2019 3:35pm |
OsloBlue Member Since: 14 Jul 2018 Location: Essex Posts: 823 |
Tried to fir Some LED backlights to my Dash, Tried being the operative word.
The T5s Went in Ok, with exception to the rev counter which is too long to fit, I think it needs the same lighting connection as the fuel indicator and engine temperature gauges. The 509Ts were a total disaster, i spend a good 45 minuted trying to fit the damn things and i managed to get only one in before it went dark, no problems i was going to do the next one Day after. After fiddling for 40 minutes, I got the second one in. Only problem is it had the wrong polarity, no problems. I pulled it out, or so i thought. Instead i pulled the first one and now couldn't get either one in. But its ok, because the connectors snapped... Go to put the old ones in... Don't work... Whoever designed the defender VDO speedo must have been an evil genius. and whoever assembled them must be doing penance for something. I'm on IG: https://www.instagram.com/osloblue42/ Current: TD5 '110 "Lucinda" Thread here: https://www.defender2.net/forum/topic62562.html |
20th Jan 2019 4:56pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Snow is forecast hereabouts this week. Bring it on. I fitted my winter tyres today.
Having been following the current thread about half shafts, whilst the wheels were off I checked for wear at the flanges. Sure enough, looks like I have found another job to add to my list. In line with what others are experiencing, the o/s wear is more prominent. |
20th Jan 2019 6:47pm |
AlpinistG Member Since: 15 Dec 2015 Location: Scotland Posts: 64 |
Had day on hill then sunset drive.. perfect
20th Jan 2019 7:23pm |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
Huttopia Member Since: 23 Feb 2016 Location: West Midlands Posts: 1978 |
I took the pick up shooting on Saturday and giggled as the assorted Discoveries and Range Rovers slithered all over the place on fat tyres. Standard Michelin Latitudes worked well. The Heritage also went for its third service for the princely sum of £155. Yesterday I took my son to play hockey at a tournament in Solihull, so the pick up trundled up the M5/M42. There is something quietly satisfying about using the same vehicle for chugging across muddy fields one day and pootling along the motorway the next. Good old 300tdi
21st Jan 2019 7:51am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5771 |
I love it when these bigger, and better off road vehicles (according to Land Rover, and the owner) struggle and the “crappy” Defender just drives past
21st Jan 2019 8:32am |
Slideywindows Member Since: 09 Sep 2016 Location: North Essex Posts: 1286 |
Or on the shoot I go to: the "crappy" ancient Series IIA drives past.
21st Jan 2019 10:24am |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Theres some stunners here, really need to get out in my defender more.... and not just daily for work... Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
21st Jan 2019 11:46am |
Another day out testing our new 12 inch travel suspension set up!
21st Jan 2019 3:34pm |
WOW!!! Regards
21st Jan 2019 3:44pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20558 |
Is that a set up by King suspension by any chance? KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st Jan 2019 4:44pm |
